Hi!
So I'm new to using image textures and UV's and I've stumbled across a problem.
On one part of the Coffee Grinder I'm texturing the Uv's are acting weird. How can I fix this?
I tried redoing the UV's of this speific part but I ended up with the same thing happening.
These are my UV's that I have applied at the moment btw. I added small red dots to the Shells that are the ones from the part that's not working right.
Solved by mspeer. Go to Solution.
Hi!
Please check for multiple UV Sets.
For further help, please upload a scene-file.
aah Yeah when selecting thge UV set it showed the UV's of the weird looking part in the completely wrong scale etc. so fixing that solved it.
Thank you very much!!
