UV issue after applying remesh and retopology
maleforsaling
Message 1 of 11
maleforsaling
Hello everyone,
Can someone tell me what is happening with my model?
I have a model with texture. After applying the remesh and retopology UV is disappearing. It looks like I can't apply UV at all.
Does anyone have an idea what I did wrong?
Thank you in advance!
Replies (10)
Message 2 of 11
damaggio
remesh creates a new mesh, you lose the UVs, you’ll need to do  a UV transfer from the original.
Message 3 of 11
damaggio
remesh creates a new mesh, you lose the UVs, you’ll need to do  a UV transfer from the original.This will be fixed in the future releases.
Message 4 of 11
maleforsaling
Thank you for the reply!
Actually after remesh UV is visible and is working. Just after using "retopology" UV is not working. I tried to transfer. Did not help
Message 5 of 11
damaggio
Great, good that is working.
Message 6 of 11
maleforsaling
Actually it doesn't because I'm using retopologize
Message 7 of 11
damaggio
You said the transfer didn't work but without explaining your steps and settings I have no idea why it didn't work, You have to explain better when you reply.
Also remember to read the documentation.
I'll  check back tomorrow, closing shop.
Message 8 of 11
maleforsaling
Selected the model with UV and later without -> Mesh -> Transfer attributes -> Transfer.
Settings as on the picture below.
Message 9 of 11
damaggio
Thank you for your image settings Mal, I think that the Component option is better or designed for Transferring UVS to a duplicated mesh with the same vert ID numbers, for Retopo, try in World space as I did here with a military scan and it worked fine.TransferUVS.jpg
Message 10 of 11
maleforsaling
Thank you so much!
World space worked partly. Transferred but orientation was wrong. But with option "Local" it worked just fine!
Thank you!!!
Message 11 of 11
damaggio
Awesome, good luck with your model.
