Urgent! Lambert-based textures render as pure black
Hi, I'm new to 3d and I'm currently taking a course in it for college, and our first assignment is due monday!
I have a set of textures using Lambert linked to jpg images, and are UV-mapped onto objects. I also have one blinn texture that is naturally black, but is reflective like a mirror. They render fine when editing the object, however,
THE ISSUE: When imported into a scene containing a Vue landscape (I have Vue XStream installed) and rendered, everything renders fine including Blinn material except for the lambert materials. They are pure black. I also tried adding a seperate, new Lambert material within the scene and have it a plain color, still turns black.
I have no idea how to fix this and I dont want to start texturing from scratch again, it took me all day!
A few notes: For XStream, I had to apply photometric things to the cameras, mia_photometric_material or something like that to the cameras, so that it wasnt over exposed with Vue's sun. Is this the reason? why would Blinn material render fine then?
damaggio
Just make it all Blinns Hiza.
J450NP13
Or see if you can select the faces and reverse them.
Turns out, the X-stream plugin's default lighting only lights Vue objects and scenery. I had to add a two directional lights (in opposite directions) to light the maya objects in the scene.
I think they were 2000 and 10000 in intensity.
