UDIM texture file Grey in Viewport
I mapped a udim texture file onto the rig im currently animating
it wont show up in the viewport, but it shows in the render
i will be unable to render this animation so ideally i would like to have it show in the playblast
Did you ever find a solution to this? I'm having the same issue.
Just replying so anyone with the same problem in the future could get it solved.
You need to generate the preview on all the UV tiles. There are many ways to do so:
  1. Run the generateAllUvTilePreviews; mel command with the script editor.
  2. Select the file no de and hit the red button [Generate Preview*] (you must do it for every single file node).
  3. In your viewport menu, go under the Renderer tab and open the viewport 2.0 settings. Click the button that says [Regenerate All UV Tile Preview Textures] in the Maximum Texture Resolution Clamping section.
