trying assign texture file to aistandardsurface base node in hypershade
omid1010ork
omid1010ork
  • I'm tried to connect texture file to base node in aistandard surface material but it doesn't appear in render
Stephen.Blair
Screenshot? what are you connecting to what?
You should just connect an aiImage to the base color on an aiStandardSurface
And provide a valid path to a valid texture file
// Stephen Blair
// Arnold Renderer Support
omid1010ork
 mistakenly I forgot to uploade my screenshot.
I mean I want to connect file node output alpha to base channel of aistandardsurface. But I don't see the texture that I put in my file node. Could you explain?
omid1010ork
omid1010ork
Stephen.Blair
Ok, so you want to use the alpha as the base weight.
Most likely the texture does not have an Alpha channel
Add an aiColorCorrection node, and enable Alpha is Luminance
// Stephen Blair
