Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Transparency map doesn't work
1 REPLY 1
613 Views, 1 Reply
I`m realy new into maya, so if my question is pretty silly, I apologize in advance.
what I want to do is to get a half-transparent texture on the model with an nontransparent pattern on it.
i created new lambert material, add a texture file to it and transparent map.
so in hypershade, in the materials pallet it's looking fine, just as i wanted it to be
but in material viewer, viewport and after render my material doesn't have any transparency
so is there any solution to this? or i'm doing something wrong?
1 REPLY 1
mspeer
Hi!
You use  some nodes or a network connection that's supported for Software Rendering but not for Hardware Rendering.
Please upload the scene-file (you can assign the material to a simpler object if you don't want to share your model or keep Polygon count low).
