Texture Reference Object not Working
I'm using Maya 2016 and can't seem to get rid of texture swimming with the Texture Reference Object.
After applying a 2D texture as a projection to a polygon object, when I go to Texturing > Create Texture Reference Object, it is indeed created, but the texture still swims when the object moves.
I've attached the scene here.
I'd appreciate any help!
Thank you.
mspeer
Hi!
This seems to be a bug (also in Maya 2017) with Viewport 2.0, switch to Legacy High Quality Viewport.
Anyway in software rendering it should be fine, independent of the display in Viewport.
Please report this problem (bug?) to Autodesk.
Help -> Speak Back -> Report a Problem
Thanks!
