I am learning rigging in Maya by reading a book. The following are steps introduced in the book to import a model accompanying the book:
I exactly followed the steps but what I got in Maya is a model without any texture:
From the screenshot you can see I have activated the Smooth Shade All and Textured viewport display buttons, but the texture just doesn't show. The accompanying model files are attached in this thread for your experiment. Anyone familiar with importing Wavefront OBJ file please help. Since my skill range of Maya is not wide, please tell me what menu item to select or what button to press to have the character textured. Thanks a lot.
Solved by pshwayka. Go to Solution.
Click on the model, and go to the attribute tab for the Zombie_F:Wire material. Click on the arrows indicated below, and use the folder icons to navigate to the location of the textures that are called out.
