Surface shader with transparency map problem
jhonatan.chambi
jhonatan.chambi
Hello everyone, i dont know why but my object with surface shader appears with invert transparency, i mean transparency map don't work well. i plug my transparency map in the transparency slot. Very simple connections
Please, how to fix that? Because my connection?, i work in arnold render, here there is a file for downloading with this problem
Thank you so much for your help, greetings from Lima - Peru
mspeer
Hi!
1. I recommend to use Arnold Shaders with Arnold (better support).
2. If you need something inverted, then invert it with an Utility node in Maya (reverse,...), in your case you need one that's supported by Arnold.
jhonatan.chambi
Thank you so much, finally work fine!!! it's with reverse node Smiley Happy
