Announcements
Skin shader renders blue
amnguyenERSXD
amnguyenERSXD
I created an aistandard surface and added one of the preset skin shaders for the eyelids. It looks fine in the viewport but when I render with Arnold, it looks blue for some reason. Would anyone happen to know the cause of this? Any help is appreciated.
Christoph_Schaedl
lower the scatter radius.
If its to high green gets mixed into the color.
https://linktr.ee/cg_oglu
amnguyenERSXD
I'm not sure, because the shader works for the rest of my model. It's only blue when I apply it to the eyelids.
Christoph_Schaedl
Thats cause the eyelids are much thinner than the body.
The light is passing throu.
amnguyenERSXD
Thank you for the quick reply. Is there some sort of setting I can tweak to get the eyelids to match with the rest of the skin? I tried making a normal aistandardsurface shader with the same color as the skin but it just doesn't look quite right.
Christoph_Schaedl
sometimes combining does help.
but it looks like the blue effect does also appear on the ears.?
How big is your char in cm.?
