Hi all
Is there a way of changing all selected textures in the graph Hypershade, to Raw Color Space.
I thought about adding a Rule Priority in the Prefs, but we currently have no consistency in the file names, so am thinking of another way to change all selected textures to Raw.
Cheers
Solved by mspeer. Go to Solution.
Hi!
Use Attribute Spread Sheet
or a custom script for this.
Hi!
Yes, sorry, you are right.
Then the only way is to use a custom script.
You should be able to do this with a simple for-loop.
Example selected file nodes to-Raw:
string $fnode_selection[] = (`ls -sl`); for ($fnode in $fnode_selection) { setAttr ($fnode + ".cs") -type "string" "Raw"; }
Example selected file nodes to-sRGB:
string $fnode_selection[] = (`ls -sl`); for ($fnode in $fnode_selection) { setAttr ($fnode + ".cs") -type "string" "sRGB"; }
