Script to Batch Convert Shaders to Renderman?
l've imported an FBX file into Maya and of course all of the shaders are Phong, obviously Renderman doesn't support Phong. Normally I would just go into Hypershade and do it manually, but are well over 300 hundred texture and shader nodes. So I was curious to know if there's a script available that could easily convert the Phong shaders to PxrSurface shaders? I know such a script exists to convert Phong shaders to Mia materials for Mental Ray.
Here's the code, it works well, and I've tried editing it for Renderman's PxrSurface to no avial. I am a 100% novice in all forms of coding so any help would be much appreciated.
proc connectAndSet(string $original,string $target){
  $conn=`connectionInfo -sfd $original`;
  if ($conn!=""){
    connectAttr -force $conn $target;
  } else {
    connectAttr -force $original $target;
    disconnectAttr $original $target;
proc convertPhongToMia(string $original){
  $target=`mrCreateCustomNode -asShader "" mia_material`;
  connectAndSet($original+".color",$target+".diffuse");
  //... any other mapping you need comes here...
  // a bit weak test should work for simple materials,
  // not used in special context
  $sg=`connectionInfo -dfs ($original+".outColor")`;
  if ($sg[0]!=""){
    $sgr=`match "[^.]*" ((string)$sg[0])`;
    connectAttr -force ($target+".outValue") ($sgr+".miMaterialShader");
    connectAttr -force ($target+".outValue") ($sgr+".miPhotonShader");
    connectAttr -force ($target+".outValue") ($sgr+".miShadowShader");
  delete  $original;
  rename $target $original;
for ($item in`ls -et phong`)
  convertPhongToMia($item);
I realize this post is from a couple years ago, but I had the same question and thought it might be helpful to add the code that I ended up using.
Modified the original from: https://forum.highend3d.com/t/batch-converting-materials/45302
to convert simple lambert materials to PxrSurface (color only, not sure what to add for texture, etc).
  if ($conn!=""){
  } else {
proc convertlambertToRenderman(string $original){
  $target=`shadingNode -asShader PxrSurface`;
  connectAndSet($original+".color",$target+".diffuseColor");
  // not used in special context  delete  $original;
  if ($sg[0]!=""){
    connectAttr -force ($target+".outColor") ($sgr+".surfaceShader");
  if($original != "lambert1"){
    delete $original;
for ($item in`ls -et lambert`)
  convertlambertToRenderman($item);
