scattering volume option missing
dr.ranaldi
dr.ranaldi
Hello I can't find the "create scattering volume" option in Arnold environment render options.
I just find "create fog" o "create atmosphere volume". Is there any plugin I should load first?
I use Maya 2020. Thank you
Stephen.Blair
Arnold 5 (released April 2017):
Renamed volume_scattering node to atmosphere_volume to clarify its purpose.
// Stephen Blair
// Arnold Renderer Support
dr.ranaldi
I’ve already tried to take advantage of the new “atmosphere volume” in Arnold 5 but without any result. I mean that I created a directional light coming through some windows and activated the atmosphere volume in arnold render options so that I could get a dusty lighting, the so called “God rays effects “, but nothing happens. Even increasing the atmosphere density in the attribute editor it seems there’s no change. That’s why I thought atmosphere volume was not the right option and maybe there was something missing in arnold render options menu. Waiting for some help if you can. Thank you
mspeer
Hi!
This does not work with Directional Light, please use an other light type.
