RIB archive question
Hopefully there should be an easy answer for this one..
I've been given a Maya scene file that includes a lot of trees and bushes etc, which have all been referenced as RIB archived files, I guess to make navigating around the scene a little easier.  Because the scene was made by someone else all the file paths are for a different hard drive location.  This was an easy fix for the textures using the in-built file path editor, however I can't seem to find an easy way to do the same for all the RIB archives.  Is there an easy way to change these all at once?
Thanks in advance
mspeer
