Hi!
I'm using Shave and Haircut 9.5 and mtoa 2.01 (Arnold 5).
Everything renders perfectly until I try to use instance object. When I push render button Maya crashes. If I choose Maya renderer there are messege: "The Maya renderer does not support Hair Primitives hair render mode. We'll use Buffer render mode instead.".
Google didn't help.
Does anyone have guesses about that problem?
I don't need to guess. The Shave API doesn't provide access to instances, so Shave instances are not supported in the renderer.
Thank you for replying, Stephen! Is there any common solutions for that situation?
