Rendering scenes with multiple camera workflow
wreliford
wreliford
What is the best workflow when working with scenes with multiple overlapping cameras? Some cameras have different angles on the scene but only using a portion of the frame count.
For example: camera_001 is position at one angle for frames 001-100 while camera_002 is position at an opposite angle for frame 50-150. I may have other cameras with successive frame count covering different areas of the scene like:
camera_003 for frames 150-250
camera_004 for frames 250-400
camera_005 for frames 400-500
...and so on.
When rendering, must I separate out each camera to its own scene?
I know in the Rendering Panel you can chose your renderable camera, but this just for
There got to be a better way.
William
_sebastian_f
first 2 options coming to my mind are:
1: create a batch file were you can tell maya exactly to render specific cameras for specific frames etc. (i.e. http://www.quilime.com/code/maya_render_bat )
2: create a "master" camera and create animated constraints (i.e. point, orient) to the other cams and render that one!
wreliford
Thanks Sebastian...I thought about that too. I guess what I really want to know is that do I have to break out the cameras in separate scenes especially if the cameras are over lapping in frames like camera001 render frames 100-250 and camera002 renders frames 150-300.
I was thinking there must be a reason why you could pick and chose your renderable camera in the render panel. I thought it was because you can render both cameras simultaneously from just the one scene file.
I guess I was just hoping.
_sebastian_f
hi wreliford,
you dont have to break it up in different scenes for the above mentioned workflows. but for sure with overlapping frames you´ll have to take the batch file approach.
would be a nice feature to have frame ranges per camera, for now it will just render the different cams after each other but for the same frame range.
last but not least i forgot about the maybe most simple solution: put your whole scene in different renderlayers (one per cam) and create overrides for the renderable camera and the frame ranges!
tony.su
Autodesk Support
Autodesk Support
Render from the command line using mental ray.
http://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Maya/file...
And this is an bat example file.
"C:\Program Files\Autodesk\Maya2015\bin\Render.exe" -cam camera_001 -s 1 -e 50 C:\render\myfile.mb
"C:\Program Files\Autodesk\Maya2015\bin\Render.exe" -cam camera_002 -s 51 -e 150 C:\render\myfile.mb
"C:\Program Files\Autodesk\Maya2015\bin\Render.exe" -cam camera_003 -s 151 -e 250 C:\render\myfile.mb
"C:\Program Files\Autodesk\Maya2015\bin\Render.exe" -cam camera_004 -s 251 -e 400 C:\render\myfile.mb
"C:\Program Files\Autodesk\Maya2015\bin\Render.exe" -cam camera_005 -s 401 -e 500 C:\render\myfile.mb
Tony Su
Product Support
