Rendering reflections only with render setup
harri.seppala
Observer Observer
harri.seppala
Observer
Observer
I can't figure this out 😞
I'd simply like to setup where one render layer renders only reflections of a sphere.
Disabling sphere from render stats-> primary visibility does what I expect (result_I_want.png) but when I set this with Render Setup it doesn't work.
I've tried closing and opening Arnold render view and many other things but no matter what I do it always renders the full scene (result_I_get.png).
Many thanks for help
Maya 2022.4 / MacOs
harri.seppala
Observer
Observer
This is likely a common thing to do. Nobody knows?
harri.seppala
Observer
Observer
Still nobody? 😞
Please Autodesk, I’d really need this to work.
Thanks!
Christoph_Schaedl
Make sure the layer you are working on is active. Otherwise the change wont get saved.
https://linktr.ee/cg_oglu
