- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So i'm trying to keep my cool right now but I'm getting to that limit.
Ok so I've been trying to use the stupid Render layer system to render out the ZDepth sequence.
I followed all the steps from the Render layer setup on how to create the layers and their orders.
I set the Render view AOV to Z so I can see what I am doing because the ZDepth is all I need.
I test render, everything looks great, I'm viewing at -10 in the render preview since there is no way to make the depth adjustment like before.
I go to render the sequence and I get either all black or all white
I bring in nuke and step up..Nothing,, all flat,
I go do the same for the white... nothing. all flat.
I go back to my render.. save as exr.. save raw from the Render preview.. bring in nuke.. presto.. depth pass looks great..!!!!!!
sooooooo Why am I not able to get the same results for the sequence. I've tried to even just use the master with no layers created.. nothing works.
I've brought the AOV down over the collection in the layer, that doesn't work.
I tried to do the old way with using the surface shader but since 2017 doesn't have render layers with luminance presets, I cant use that method. I cant use the other renderers because its Arnold based.
So how in the heck am I supposed to get the renders to show when using the Render Layers as apposed to "saving As" from the render window?
I have over 2k frames to render and I cant save as each one.
AOV settings are (see image below)
PLEASE HELP HELP HELP!!!!!
LOAD ME A TEST FILE THATS EVEN SETUP WOULD WORK..
