Render Setup Material Override not working on aiStandin?
I've created a material override in Render Setup so I can create a Ambient Occlusion layer. I've assigned all geometry including the aiStandin. They all appear in the render but only the aiStandin does not carry the Ambient Occlusion. It just renders as beauty (See image attached, bottom right is a chair which is the Standin)
Any idea why? Thanks
jeffC8BTD
Did you ever figure this out? I'm having the same issue.
Christoph_Schaedl
Have you assigned a shader to the standin?
https://linktr.ee/cg_oglu
Type a product name
