Render just shadows?
kenne150
kenne150
Is there a way to Render just the shadows of an object without rendering the object itself? I'm using a shadow matte plane if that makes a difference. I've tried to turn visibility of the objects off a couple of different ways, but it also turns off the visibility of the shadows. I just need to shadows rendered for a project. thanks.
damaggio
Yes you can render almost anything separately for compositing in any 3D application.
Watch some render set up videos and look in the Maya documentation.
mspeer
Hi!
Disable in the Shape node:
Render Stats -> Primary Visibility
