Much thanks...yes just needed to fish with more settings, visibility didn't work in the shape node, but the Renderman node under the Trace attributes/Visibility>camera Visibility>no....Now I can render seperate lit objects to export into nuke for a glow composite,....Etc.....Thank you, and you helped me before on something.
Nate Kraw
HP I-7 8700
32 GB RAM
Nvidia Quadro P600
Nate Kraw
HP I-7 8700
32 GB RAM
Nvidia Quadro P600
Yes, the visibility control is under some HDR environment attribute of an specific rendere ( they vary), Renderman, Arnold, Vray, Redshift....good thing you found on your own.
Cheers.
Cheers.
