Particles Visible in Viewport but Not Render
samjam_3d
samjam_3d
I want to make my particles not render, but I still want them visible in the viewport.
How do I do this in Maya?
pshwayka
Assuming you're using Maya 2017 with Arnold...you can go into your nParticle shape node attributes, and under the Arnold section set the Maximum Particle Radius to 0.
samjam_3d
I'm using 2016, but I'm not using the nParticles, I'm using the legacy particles through fumeFX because the nParticles don't play nice with FumeFX
mspeer
Hi!
The solution to display particles in viewport without rendering is Renderer dependent.
In Attribute Editor (particle or particleShape): Display -> Template (enable)
- This prevents color rendering and selection in viewport for the particles, but should do what you asked for.
Example for Mental Ray, Attribute Editor (particle): mental ray -> Flags -> Visible "No"
- No limitation for Viewport display.
samjam_3d
Thanks very much!
I actually figured out a way to do it by changing my particle type to (software) which would then allow me to turn off the "Primary Visibility."
Now I have three ways to do it 🙂
