Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
parallax bump map
4 REPLIES 4
1974 Views, 4 Replies
parallax bump map
Can I set up "parallax bump map" with arnold shaders?
parallax bump map
4 REPLIES 4
mspeer
mspeer
Hi
I don't think so.
Hi
I don't think so.
in reply to: mspeer
hi mspeer, thanx for reply
Ok, I gave up it.
Ok, I gave up it.
For some reason, if you create a torus (sometimes a sphere, cone or cylinder too) in your scene and leave your bound padding to 0.000, it will transform your Displacement Map in a Parallax Mapping, it doesn't do that with a cube, for instance, my plane at a 5 iterations takes 24secs to render. With a torus, it's 12 seconds, look at the image I created to show you the difference.
mspeer
mspeer
Hi!
Parallax Mapping is not the same as Displacement Mapping.
So what you get is not Parallax Mapping it's still Displacement Mapping but cut to some bounds.
Hi!
