Hello everyone!
I have a problem with the painter effects brushes, when trying to use, for example, trees, it doesn't make the thorns, the leaves, etc... it leaves everything flat and the message in the console is the following:
// Warning: WARNING | [maketx] make_texture ERROR: Could not open "C:/Program Files/Autodesk/Maya2024/brushImages/wrapBark_sRGB_ACEScg.iff.c27f1336.temp.tx" : Could not open "C:/Program Files/Autodesk/Maya2024/brushImages/wrapBark_sRGB_ACEScg.iff.c27f1336.temp.tx" (Permission denied)
Here is a render with the trees:
Could anyone know what is wrong?
Thank you very much for your time, greetings
Jesús
