Hi everyone,
For some reason i can't seem to figure this one out, and I'm sure it's right under my nose..
How can I add an override in Render Setup for an object's file texture, but keep the file connected to Bump Mapping the same?
Right now, whenever override the object's texture, that also becomes the bump.
Any help on this would be greatly appreciated.
Thanks!
An
Solved by _sebastian_f. Go to Solution.
Thanks for your quick reply @_sebastian_f. That seemed to work, in the viewport anyway. However, the textures will not render with Arnold.
Here are my two test layers, with the same bump but different textures:
In the Arnold IPR and the regular Render View, they both render like this:
It's as if Arnold doesn't "see" the textures somehow.
Ideas?
I threw a third texture onto the default layer, and as you can see it renders fine.
Here is a shot of my render setup. I can of course upload the scene file if you need.
Thanks again.
Nope, @_sebastian_f unfortunately that doesn't change the textures at all, in the viewport or render.
Nevermind! It worked!
I didn't realize you needed to KEEP the absolute override, but ADD the connection override to that sub-collection like this:
Perfect. Ok, so hopefully this helps others who might be struggling with this process.
Thanks again @_sebastian_f
@andymc4997 glad you got it working. but it´s strange that you need to combine both. did you delete the layer before trying the connection override? probably some connection was left in the background!
i made a quick screencast of how i think it should work.
