Normalmap problem
Normalmap problem
foxsuno
Normalmap problem
foxsuno
Hi guys, i'm having a problem with normal map, i'm sending a print of the problem, because i really don't know what is happening, i'm using maya and Xnormal, the bump node is in tangent space normals, if you guys could help me, i would be very gratefull.
ps>i already checked my swizzles and put the normals in "average normals" in the high res
_sebastian_f
can you provide screenshots of the low poly with wireframe, the highpoly without wireframe, and the low poly uv´s? also make sure the color space of the normal maps file node is set to raw.
foxsuno
Of course, thanks
high (i was making wrinkles for normalmaps, but the problem keep occurring even in this neutral expression, i put the color space in raw and nothing changed)
UVmap
lowpoly wirframe
normalmap
_sebastian_f
hmm looks ok from what i can see here. also from the settings you mention everything should work. what do you use to render?
foxsuno
i was using maya software, i downloaded mental ray today to test and i'm getting black screen, i'm trying to fix...
foxsuno
good news, i fixed the mental ray here and did a render in it and worked 😃
Thanks for the help 😃
_sebastian_f
glad you found the solution.
