Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Normalmap problem
6 REPLIES 6
foxsuno
680 Views, 6 Replies
Normalmap problem
Hi guys, i'm having a problem with normal map, i'm sending a print of the problem, because i really don't know what is happening, i'm using maya and Xnormal, the bump node is in tangent space normals, if you guys could help me, i would be very gratefull.
ps>i already checked my swizzles and put the normals in "average normals" in the high res
6 REPLIES 6
_sebastian_f
in reply to: foxsuno
can you provide screenshots of the low poly with wireframe, the highpoly without wireframe, and the low poly uv´s? also make sure the color space of the normal maps file node is set to raw.
foxsuno
in reply to: _sebastian_f
Of course, thanks
high (i was making wrinkles for normalmaps, but the problem keep occurring even in this neutral expression, i put the color space in raw and nothing changed)
UVmap
lowpoly wirframe
normalmap
_sebastian_f
hmm looks ok from what i can see here. also from the settings you mention everything should work. what do you use to render?
foxsuno
i was using maya software, i downloaded mental ray today to test and i'm getting black screen, i'm trying to fix...
foxsuno
good news, i fixed the mental ray here and did a render in it and worked 😃
Thanks for the help 😃
_sebastian_f
glad you found the solution.
