crypto_asset should differentiate between
references.but this update renders as crypto_object
plz check attachment
Solved by gtr.bookmark. Go to Solution.
Found solution. In Arnold render settings
if "Export Full Paths" is turned off the issue getting resolved
Check the attachment for better understanding
You can also add the custom string attribute mtoa_constant_crypto_asset to the shape node and set it the same for each object you want to belong to that asset.
In my case I fixed the same / similar problem by turning off "strip obj namespaces" in the main cryptomatte AOV node.
