Missing Arnold aistandard help!
Message 1 of 13
i have recently noticed that my aistandard shader is missing, all the other shaders for arnold are there, and i used the aistandard a day or two ago but now its no where to be found, anyone any ideas? using maya 2017
Replies (12)
Message 2 of 13
faline.custodio.da.silva
@Anonymous
Down and install the latest version of Arnold for Maya.
Arnold Download
If that doesn't work then reset your Maya prefs.
Reset Maya to Default
Let me know if that works for you.
Faline Custodio Da Silva
Message 3 of 13
dimensiondynamics
Community Visitor
Community Visitor
I'm having the same problem and reinstalling Arnold and resetting the prefs have not helped.
Message 4 of 13
Stephen.Blair
As of MtoA 2.0, aiStandard is deprecated, and you won't see it in the user interface.
Use standard surface instead.
See the FAQ: https://support.solidangle.com/x/XQtkAg
// Stephen Blair
// Arnold Renderer Support
Message 5 of 13
i am also havi the same issue i but Standard Surface dosent have refraction
Message 6 of 13
mspeer
Hi!
Please read the online user guide for changes, new feature or any other type of information.
You should see new "Transmission".
Message 7 of 13
 I have installed latest version of arnold and reset pref but aistandard still missiong.
Message 8 of 13
Stephen.Blair
As stated above:
// Stephen Blair
Message 9 of 13
Hey Stephen,
while it is true that it's deprecated, the aiStandardSurface doesn't provide a refraction  tab. As someone who's working with the Arnold shader for the first time now, do you have an idea what to use instead?
I wasn't able to find any more relevant post in the forum.
All the best,
Bastian
EDIT: Solved. I overlooked the other reply with the hint towards the transmission tab. Sorry!
Message 10 of 13
moiamy
I am still trying to figure how refraction works with aiStandardSurface
Message 11 of 13
DG8393i
Go to
       Windows > Settings/Preferences > Plug-in Manager
Click Load & Auto Load for these options
mtoa.ll
Substance.mll
substancelink.mll
substancemaya.mll
substanceworkflow.py
Now close
when you right click and Assign New Material to your asset you will find the Arnold options
Apply aiStandardSurface
Base Window in outliner:
colour - apply base material
Specular Window in outliner:
Metallness - apply metallic map
roughness - apply roughness map
Geomtry Window in Outliner:
Use As: Change to Tangent Space Normals
Go to the file option - Normal map
height map needs to be done with nodes, good luck! 🙂
Message 12 of 13
gaboreturi
It's 2023 and still not solved? Maya seems to be falling apart
Message 13 of 13
lucille_raynal
Community Visitor
Community Visitor
Thank youu !!
