Mesh Not Rendering in all frames
Hi There,
Currently I am trying render my Animation using Maya Hardware 2.0 Batch Render but the problem I am Facing is when I click on batch render some of my meshes (Object) are not rendering in the scene in most of the frames.
So Basically, from 1st to 5th frames render is fine but after 5th frame few of my scene meshes are not rendering.
mspeer
Hi!
Please upload a scene-file.
I can't share the scene file. Please suggest any other option.
mspeer
Hi!
Please try switching Evaluation Mode ("Parallel" vs "DG") in Preferences.
There are a lot of things that can go wrong here and it would take me too much time to go trough all of this by single messages. Sorry, without a scene-file (much more information about your scene and settings) i am not able to help you further.
If an object is not shown, it's:
A) set invisible or hidden by an other object
B) at a different place (translation)
C) can not be created (corrupted mesh/history,...)
Here is the scene attachment..
mspeer
Hi!
I'm not sure what exactly causes the problem, but it's tied to the GPU.
HD Resolution + 16 x Multisample Anti-Aliasing+ 32 bit Floating Point Render Target is simply too much in this case.
"Software only" solutions are:
A) lowering resolution, or
B) only 8 x Anti-Aliasing, or
C) disable Floating Point Render Target
Thanks a lot.. Got the solution... Thumbs Up !!
