Maya Texture Filter
Maya Texture Filter
ethancollins9
Maya Texture Filter
ethancollins9
Good Evening
I am having a problem, My textures that come out of Substance Painter, get almost 50% more darker when imported into maya, and no matter what I do in Substance the texture is still extremely dark in Maya
Base Texture straight out of Substance
Then once I import the texture into Maya it gets insanely dark and is basically unusable. I have tried changing the color space from SRGB to RAW and no change occurs, I have lightened the texture in Substance but it doesn't fix anything, The issue is inside Maya and I don't know what setting got changed
Maya Filter Adds Darkness
Christoph_Schaedl
Looks like you are tonemapping the viewport.
https://linktr.ee/cg_oglu
ethancollins9
I have this option turned off and the texture still appears dark.
wzwow
maya still cannot blur texture with a node???
artfully3d
The Maya image you provided, is in a render window. Is it just appearing darker due to the lighting within your scene?  Apologies if the following is already how you are comparing, but just to be sure --
A good way to compare the brightness/color between the file from substance painter and the file after you have imported it into Maya is to look within the Hypershade. There is a tab near the top called Textures, which will show you a thumbnail of every external texture file in your Maya scene. The thumbnail should color match your original file from Substance.
From there you can right click the texture and choose "Test Texture", which will open it in a render window.
The initial preview, at least in my own testing, is brighter than the original until I change the render window mode to RAW. Which is here (image). In the screenshot you linked, your display mode is set to a tone map.
If this still doesn't help, a go-to resource I sometimes look back on is an article posting from Substance, it does talk about color management settings https://substance3d.adobe.com/tutorials/courses/Substance-guide-to-Rendering-in-Arnold
If it's still not working correctly, you could consider linking the texture or zip up the scene and the texture for more troubleshooting help.
ethancollins9
Thank you for the response,
The Issue was an old .tx file that was being read instead of it reading the new output texture.
