Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Maya render problems damaged files
10 REPLIES 10
Message 1 of 11
1581 Views, 10 Replies
I want to render a tif sequence in Maya 2016 Non-commercial. If i batch render it it will produce damaged filesand i can't open them in NUKE or Photoshop. What's the problem? Am i doing something wrong here?
10 REPLIES 10
Message 2 of 11
J450NP13
J450NP13
Are you getting an error.
Message 3 of 11
Here is a screen cast where i point out the problem.
https://www.youtube.com/watch?v=u5WQ3GexI7g&
And i put an inclosure damaged file in the inclosure.
Message 4 of 11
J450NP13
J450NP13
Yeah....I'm not clicking that link.
Message 5 of 11
in reply to: J450NP13
Is their an other way that i can show you the screencast
Message 6 of 11
Sorry for the link. Here it is on youtube. I hope you want to watch it.  https://www.youtube.com/watch?v=u5WQ3GexI7g&feature=youtu.be
Message 7 of 11
pshwayka
pshwayka
Your video shows that the image format is set to openEXR...not TIF. That may be your problem.
Message 8 of 11
pshwayka
pshwayka
Photoshop can't open an exr file if you have "deep image format" enabled when you render. Uncheck that on the "scene" tab of the render settings under Primary Framebuffer, then try your render again.
Edit: This seems to be a problem with other image formats also  (Jpg, etc.) when "deep image format" is enabled. It's not just limited to exr files.
Message 9 of 11
in reply to: pshwayka
I tried it with a tif format and i have the same problem
Message 10 of 11
pshwayka
pshwayka
Did you turn off "Use Deep Image Format" as I suggested?
Message 11 of 11
Yes. It works. You're a lifesaver! Thank you very much!
