Maya Duplicating Materials on Import
Message 1 of 19
Trying to move a project from Maya LT to Maya (finally upgraded). Due to the polygon export limit on LT, I broke up everything logically and exported out the FBXs with embedded media to preserve materials. Then i copied all the texture files into the new SourceImages folder. Everything is working ok, but every time I import an asset it duplicates the material if its already in the scene. Is there anyway to stop this from happening? I just want on M_ChairPlastic material, not one for every time an asset with that material gets imported. So any way to tell maya to merge these materials on import or after the fact would be extremely helpful. Thanks in advance.
Replies (18)
Message 2 of 19
damaggio
Hi Alex, in the import options there's a checkbox for Remove duplicate shading networks. try that again.
Message 3 of 19
Thanks for the advice, I did try that however it just duplicates the material in ...001, ...002 fashion.
Message 4 of 19
damaggio
Use these settings...
Message 5 of 19
CurrentImportSettings.PNGLooks like we are on the same page. It still duplicates the material on import.
Message 6 of 19
damaggio
Are you windows or mac?
Message 7 of 19
Windows 10.
Message 8 of 19
damaggio
It could be the way these files were exported, open a new scene, create a primitive with shader and export a ma file, then import back several  times to see if is working on windows 10.
Message 9 of 19
Well I did export them from Maya Lt as FBX2018 files. Embedded media. So should I export a .ma file or FBX to match those circumstances?
Message 10 of 19
damaggio
Yeah try that, I just tried with FBX but it didnt work...but works if it is a Maya scene, there must be a setting for the FBX but I can't seem to uncover.
Sorry Alex , let us know if you found a way, I gotta get back to work.
Message 11 of 19
mspeer
Hi!
@Anonymous and @damaggio .
If using Embedded Media this will (can't) work, because when importing the file, each files media content will be extracted to a separate temp folder, so the file paths do not match and the shading networks can't be merged.
Message 12 of 19
Works fine with .ma files, but thats not something LT can generate unfortunately.
Message 13 of 19
Can you clarify what you mean by "it will (can't) work"? Is there a better method for moving a scene from Maya LT to Maya that won't result in mass duplication of materials?
Message 14 of 19
damaggio
Is working with the OBJ format Alex.
Message 15 of 19
mspeer
Hi!
Simply don't use "Embed Media".
As long as the whole network and all paths are identical, merging shading networks will work correct.
Message 16 of 19
Thank you SO MUCH! Went in to work early this morning and it worked! Can't express how much I appreciate yours and everyone's help.
Message 17 of 19
I was wrong. It worked on the first few assets, but it started duplicating again on import.
Message 18 of 19
It seems to be working randomly. Some assets come in fine without duplicating materials, others come in a duplicate, some come in and use duplicates instead of originals. Its a mess. There has to be a way to migrate from Maya LT to Maya without all this headache.
Message 19 of 19
mspeer
Hi!
If it doesn't work then there is a difference somewhere in the networks.
