Maya doesn't show the DOF in the final render
I spent days trying to find a solution to why DOF wasnt showing up in my final render,i tried changing scenes to see the diffrent but no result , i'm using Maya 2019
n8skow
Are you sure you are rendering from the same camera you have the DOF setup on?
yes i'm sure
mspeer
Hi!
@Anonymous
What renderer are you using?
Please keep in mind that these settings are for the Viewport and Maya Software Renderer, other renderer may use their own settings inside the camera settings (under their own tab).
oh i use arnold render , i've seen some tutorials using depth field in
arnold , and it's worked fine with them . i don't know what the problem is
I found the solution it's was simple , i didn't increase the arpeture size in the camera arnold setting
