Maya Batch Render - RuntimeError: (kFailure): Unexpected Internal Failure
MShephardNG7YP
MShephardNG7YP
Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/mayaBatchRenderProcedure.mel line 458: RuntimeError: file <string> line 2: Unapply layer LAYER_RL failed: (kFailure): Unexpected Internal Failure
When rendering in the vray frame buffer the layer renders fine but when using the batch render the renders do not start.
In the script edit:
// Rendering with V-Ray... //
I have tried resetting my preferences, importing the scene into an empty maya scene, even rebuilding the scene from scratch and still the same issue.
There are 2 referenced scenes in the file with refence edits made to them.
Maya version 2022.3
Is there a fix for this issue?
MShephardNG7YP
Update -
Error: file: C:/Program Files/Autodesk/Maya2022/scripts/others/mayaBatchRenderProcedure.mel line 554: RuntimeError: file <string> line 2: Unapply layer LAYER_RL failed: (kFailure): Unexpected Internal Failure
The layers not being rendered are set up the same way as the layers that are rendering correctly.
