Maya 2018 Error: AiArrayGetUIntFunc: out-of-range error (128370 out of 128368)
steven9smith9
steven9smith9
i've been trying to fix this error for the past 2 hours and can't find anything online.
All i know is:
     - This only pops up when i try to render a single frame in the "Render View" window.
     - The "Arnold Render View" Window is just fine.
     - Any Rendered animation turns out to be black frames
Have you found anything? Is your problem solved?
I'm having issues with the same thing, only that it tells "182 out of 180" instead of your massive number.
It suddenly occured yesterday for no real reason, I wonder if it has to do with me having a movie going on as a texture, it could hint about the solving of this if you have it in your project as well!
steven9smith9
I actually solved this last year and forgot to post the solution. (my bad)
my solution had to do with a glitchy polygon cut. these are the steps I took to find it.
1. delete parts of your model (I deleted faces)
2. try to render it in render view again, if it fails redo the first set on a different part of the model
3. rinse and repeat.
It took me about 30 mins to find my polygon error. Mine was located on the Clone Walker in one of the front windows.
All i had to do was delete that face and rebridge the faces properly and re-cut the face the way i wanted it.
NOTICE: you will have to re-paint if your using the 3d paint tool.
Good Luck!
