Maya 2017 batch render crashing
Message 1 of 8
we have a render farm that's using Maya 2015 and v-ray.
we're trying to upgrade it to Maya 2017 and a newer version of vray but are running into an issue of the Maya batch render crashing.
its odd, it will sometimes spit out a successful frame but most of the time it will crash immediately.
below is a render log showing it render a frame then repeatedly crash trying to render more
the scene is a very basic sphere on plane with directional light
this is in Maya 2017 update 2 - vray 3.40.06 - running on windows 7
Thanks!
-Daniel
12/6/2016
Starting "C:\Program Files\Autodesk\Maya2017\bin\mayabatch.exe"
Stack trace:
Fatal Error. Attempting to save in C:/Users/sequence/AppData/Local/Temp/sequence.20161206.1237.ma
// Maya exited with status -1073741819
12/6/2016
Stack trace:
Fatal Error. Attempting to save in C:/Users/sequence/AppData/Local/Temp/sequence.20161206.1354.ma
12/6/2016
Stack trace:
Fatal Error. Attempting to save in C:/Users/sequence/AppData/Local/Temp/sequence.20161206.1357.ma
12/6/2016
Stack trace:
Fatal Error. Attempting to save in C:/Users/sequence/AppData/Local/Temp/sequence.20161206.1422.ma
12/6/2016
VP2 Error : Failed to initialize graphics device.
Failed to register registerFragments.pymel.core : INFO : Updating pymel with pre-loaded plugins: invertShape, mayaHIK, GamePipeline, CloudImportExport, curveWarp, tiffFloatReader, MASH, poseInterpolator, bifrostvisplugin, ATFPlugin, hairPhysicalShader, ikSpringSolver, ik2Bsolver, xgenToolkit, AbcExport, retargeterNodes, VectorRender, gameFbxExporter, renderSetup, OpenEXRLoader, lookdevKit, Unfold3D, Type, fbxmaya
Maya 2017 importing module pymel 1.0.9 (C:\Program Files\Autodesk\Maya2017\Python\lib\site-packages\pymel\__init__.py)
[2016/Dec/6|14:27:22] V-Ray: V-Ray for Maya version 3.40.06, revision 27073 from Nov 22 2016, 21:23:16
[2016/Dec/6|14:27:22] V-Ray: V-Ray core version is 3.25.01
Initializing V-Ray for Maya
[2016/Dec/6|14:27:23] V-Ray: Loading plugins from "C:\Program Files\Autodesk\Maya2017\vray/vrayplugins/vray_*.dll"
[2016/Dec/6|14:27:24] V-Ray: 75 plugin(s) loaded successfully
[2016/Dec/6|14:27:24] V-Ray: Finished loading plugins.
Warning: V-Ray: Could not get the renderer
Warning: };
Warning: "C:/Program Files/Autodesk/Maya2017/scripts/others/imageFormats.mel" line 65.2 : Global variable is already initialized; this occurrence is ignored.
[2016/Dec/6|14:27:25] V-Ray: Registered dynamic node vrayMultiProjection (id: 1115335/0x001104C7)
[2016/Dec/6|14:27:25] V-Ray: Registered dynamic node VRayCurvature (id: 1115347/0x001104D3)
[2016/Dec/6|14:27:25] V-Ray: Registered dynamic node VRayTriplanar (id: 1115362/0x001104E2)
[2016/Dec/6|14:27:25] V-Ray: Registered dynamic node VRaySkinMtl (id: 1115348/0x001104D4)
[2016/Dec/6|14:27:25] V-Ray: Registered dynamic node VRayPointParticleMtl (id: 1115353/0x001104D9)
[2016/Dec/6|14:27:25] V-Ray: Registered dynamic node VRayStochasticFlakesMtl (id: 1115359/0x001104DF)
Error: line 1: line 1: Cannot find procedure "shaderBallRendererMenuUpdate".
File read in  2.8 seconds.
Result: P:/_Test_Renders/maya_vray_2017/scenes/maya2017Test_04__4432.mb
Warning: int $interactive = 1; // for Flag -interactive
Warning: "C:\Users\sequence\AppData\Local\Temp\AST7E93976.tmp" line 9.21 : Redeclaration of variable "$interactive" shadows previous declaration at line 7. Previous value will be overwritten by explicit initializer.
V-Ray: Starting render
[2016/Dec/6|14:27:25] V-Ray: Exporting scene to V-Ray.
[2016/Dec/6|14:27:25] V-Ray: Parsing light links time  0h  0m  0.0s (0.0 s)
[2016/Dec/6|14:27:25] V-Ray: Translating scene geometry for V-Ray
[2016/Dec/6|14:27:25] V-Ray: Total time translating scene for V-Ray  0h  0m  0.0s (0.0 s)
[2016/Dec/6|14:27:25] V-Ray: Rendering.
[2016/Dec/6|14:27:25] V-Ray: Clearing bitmap cache memory...
[2016/Dec/6|14:27:25] V-Ray: Rendering frames.
[2016/Dec/6|14:27:25] V-Ray: Updating frame at time 1.00
[2016/Dec/6|14:27:25] V-Ray: Total time updating frame  0h  0m  0.0s (0.0 s)
[2016/Dec/6|14:27:25] V-Ray: Preparing renderer...
[2016/Dec/6|14:27:25] V-Ray: Using Intel Embree ray server
[2016/Dec/6|14:27:25] V-Ray: Preparing scene for rendering...
[2016/Dec/6|14:27:25] V-Ray: 1 lights found.
[2016/Dec/6|14:27:25] V-Ray: Max ray intensity is enabled: rendered result may have incorrect brightness.
[2016/Dec/6|14:27:25] V-Ray: Preparing scene for frame...
[2016/Dec/6|14:27:25] V-Ray: Compiling geometry...
[2016/Dec/6|14:27:25] V-Ray: Using embree ray tracing.
[2016/Dec/6|14:27:25] V-Ray: Building embree static accelerator ...
[2016/Dec/6|14:27:25] V-Ray: Building embree static trees took 97 milliseconds
[2016/Dec/6|14:27:25] V-Ray: Rendering image...
[2016/Dec/6|14:27:25] V-Ray: Start progressive rendering, server mode 0, perform rendering 1
[2016/Dec/6|14:27:25] V-Ray: Progressive sampling base buffer memory usage: 16.17 MB
[2016/Dec/6|14:27:25] V-Ray: Additional progressive sampling filter buffers memory usage: 178.18 MB
[2016/Dec/6|14:27:26] V-Ray: Noise threshold lowered to 0.142857 with 12.5 percent active pixels.
[2016/Dec/6|14:27:27] V-Ray: Noise threshold lowered to 0.090909 with 0.2 percent active pixels.
[2016/Dec/6|14:27:27] V-Ray: Noise threshold lowered to 0.052632 with 0.3 percent active pixels.
[2016/Dec/6|14:27:27] V-Ray:  (Estimated time remaining:  0h  0m 11.7s): 13 % completed
[2016/Dec/6|14:27:27] V-Ray: Noise threshold lowered to 0.028571 with 0.9 percent active pixels.
[2016/Dec/6|14:27:27] V-Ray:  (Estimated time remaining:  0h  0m  5.9s): 24 % completed
[2016/Dec/6|14:27:27] V-Ray: Noise threshold lowered to 0.014925 with 1.7 percent active pixels.
[2016/Dec/6|14:27:27] V-Ray:  (Estimated time remaining:  0h  0m  2.4s): 46 % completed
[2016/Dec/6|14:27:27] V-Ray: Final noise threshold set: 0.010000
[2016/Dec/6|14:27:27] V-Ray:  (Estimated time remaining:  0h  0m  0.1s): 96 % completed
[2016/Dec/6|14:27:30] V-Ray: Progressive rendering finished: specified noise level reached
[2016/Dec/6|14:27:30] V-Ray: Sampling level reached: 13.15 subdivs (496 passes)
[2016/Dec/6|14:27:30] V-Ray: Number of raycasts: 18132871 (34.98 per pixel)
[2016/Dec/6|14:27:30] V-Ray:   Camera rays: 1527587 (2.95 per pixel)
[2016/Dec/6|14:27:30] V-Ray:   Shadow rays: 9408884 (18.15 per pixel)
[2016/Dec/6|14:27:30] V-Ray:   GI rays: 0 (0.00 per pixel)
[2016/Dec/6|14:27:30] V-Ray:   Reflection rays: 7196400 (13.88 per pixel)
[2016/Dec/6|14:27:30] V-Ray:   Refraction rays: 0 (0.00 per pixel)
[2016/Dec/6|14:27:30] V-Ray:   Unshaded rays: 0 (0.00 per pixel)
[2016/Dec/6|14:27:30] V-Ray: Number of light evaluations: 2715705 (5.24 per pixel)
[2016/Dec/6|14:27:30] V-Ray: Number of intersectable primitives: 960
[2016/Dec/6|14:27:30] V-Ray:   SD triangles: 960
[2016/Dec/6|14:27:30] V-Ray:   MB triangles: 0
[2016/Dec/6|14:27:30] V-Ray:   Static primitives: 0
[2016/Dec/6|14:27:30] V-Ray:   Moving primitives: 0
[2016/Dec/6|14:27:30] V-Ray:   Infinite primitives: 0
[2016/Dec/6|14:27:30] V-Ray:   Static hair segments: 0
[2016/Dec/6|14:27:30] V-Ray:   Moving hair segments: 0
[2016/Dec/6|14:27:30] V-Ray: Successfully written image file "P:/_Test_Renders/maya_vray_2017/images/maya2017Test_04.png"
[2016/Dec/6|14:27:30] V-Ray: Total frame time  0h  0m  5.4s (5.4 s)
[2016/Dec/6|14:27:30] V-Ray: Total sequence time  0h  0m  5.4s (5.4 s)
[2016/Dec/6|14:27:30] V-Ray: Render complete
[2016/Dec/6|14:27:30] V-Ray: ========================
[2016/Dec/6|14:27:30] V-Ray: Clearing exporter memory...
[2016/Dec/6|14:27:30] V-Ray: Total time clearing exporter memory  0h  0m  0.0s (0.0 s)
Scene P:/_Test_Renders/maya_vray_2017/scenes/maya2017Test_04__4432.mb completed.
Replies (7)
Message 2 of 8
cornelh
@Anonymous
Here is another post which had the same issues as you.  Please read the post and follow the solution I provided (it is the same as the one we did via teamviewer)  Good luck!
http://forums.autodesk.com/t5/maya-shading-lighting-and/can-t-batch-render-mental-ray/m-p/6719769#M18197
Message 3 of 8
sadly this did not solve my problem.
The batch render will still crash randomly at launch.
My workstation batch renders fine, this issue is happening on a render node on our farm.
Message 4 of 8
SVAbfacad
Just to chime in here - I am having the same problem with Maya 2017 Update 2, Arnold 1.4.1.1 and all batch rendering... whether it is as part of the renderfarm or on a local batchrender.
In fact, my latest experiment turned up this error:
12/27/2016
00:00:00   225MB WARNING | [mtoa] [bifrostTranslator] [node bifrostFoamMaterial] Assigning temporary node id 1138176 to associated Maya type name bifrostFoamMaterial.
00:00:00   225MB WARNING | [mtoa] [bifrostTranslator] [node bifrostAeroMaterial] Assigning temporary node id 1138177 to associated Maya type name bifrostAeroMaterial.
00:00:00   226MB WARNING | [mtoa] [shave] [node ShaveHair] Assigning temporary node id 1138178 to associated Maya type name shaveHair.
00:00:00   233MB WARNING | [mtoa] Extension bifrostTranslator(C:/solidangle/mtoadeploy/2017/extensions/bifrostTranslator.dll) requires Maya plugin bifrostvisplugin, registering will be deferred until plugin is loaded.
00:00:00   233MB WARNING | [mtoa] Extension hairPhysicalShaderTranslator(C:/solidangle/mtoadeploy/2017/extensions/hairPhysicalShaderTranslator.dll) requires Maya plugin hairPhysicalShader, registering will be deferred until plugin is loaded.
00:00:00   233MB WARNING | [mtoa] Extension shave(C:/solidangle/mtoadeploy/2017/extensions/shave.dll) requires Maya plugin shaveNode, registering will be deferred until plugin is loaded.
00:00:00   233MB WARNING | [mtoa] Extension xgenSplineTranslator(C:/solidangle/mtoadeploy/2017/extensions/xgenSplineTranslator.dll) requires Maya plugin xgenToolkit, registering will be deferred until plugin is loaded.
00:00:00   233MB WARNING | [mtoa] Extension xgenTranslator(C:/solidangle/mtoadeploy/2017/extensions/xgenTranslator.dll) requires Maya plugin xgenToolkit, registering will be deferred until plugin is loaded.
Successfully imported python module 'arnold'
Successfully imported python module 'mtoa'
pymel.core : INFO : Updating pymel with pre-loaded plugins: GPUBuiltInDeformer, deformerEvaluator, mtoa, renderSetup
Maya 2017 importing module pymel 1.0.9 (C:\Program Files\Autodesk\Maya2017\Python\lib\site-packages\pymel\__init__.pyc)
Successfully registered renderer 'arnold'
File read in  2.7 seconds.
Result: //prod/class/rhagen/test/scenes/test_2017_RS_Arnold__11404.mb
Warning: "C:\Users\rhagen\AppData\Local\Temp\AST4AF35800.tmp" line 9.21 : Redeclaration of variable "$interactive" shadows previous declaration at line 7. Previous value will be overwritten by explicit initializer.
00:00:00   351MB         | log started Tue Dec 27 20:08:15 2016
00:00:00   351MB         | Arnold 4.2.16.0 windows icc-14.0.2 oiio-1.7.7 rlm-12.0.2 2016/11/22 13:25:15
00:00:00   351MB         | host application: MtoA 1.4.1.1 0c2807b2 (HEAD) Maya 2017
00:00:00   351MB         | running on RENDER30, pid=1856
00:00:00   351MB         |  2 x Intel(R) Xeon(R) CPU E5-2695 v2 @ 2.40GHz (24 cores, 48 logical) with 65502MB
00:00:00   351MB         |  Windows 8 Enterprise Edition (version 6.2, build 9200)
00:00:00   351MB         |  soft limit for open files raised from 2048 to 2048
00:00:00   351MB         |
00:00:00   351MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/mtoa_shaders.dll ...
00:00:00   352MB         |  mtoa_shaders.dll: MayaMultiplyDivide uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaClamp uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaGammaCorrect uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaCondition uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaReverse uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaBlendColors uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaSamplerInfo1D uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaSamplerInfo2D uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaPlusMinusAverage1D uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaPlusMinusAverage2D uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaPlusMinusAverage3D uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaRemapValueToValue uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaRemapValueToColor uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaRemapColor uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaFile uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaPlace2DTexture uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaRamp uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaProjection uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MeshInfo uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaChecker uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaBulge uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaCloth uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaGrid uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaFractal uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaNoise uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaPlace3DTexture uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaRgbToHsv uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaHsvToRgb uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaLuminance uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaCloud uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaCloudAlpha uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaSnow uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaContrast uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaLayeredTexture uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaLayeredShader uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaSolidFractal uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaVolumeNoise uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaBrownian uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaStucco uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaRemapHsv uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaSetRange uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaImagePlane uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaSurfaceShader uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: colorToFloat uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: vectorToFloat uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: pointToFloat uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: point2ToFloat uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: writeColor uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: aovWriteColor uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: writeFloat uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: aovWriteFloat uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaEnvSphere uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: anim_matrix uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: anim_float uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: anim_point uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: anim_vector uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: anim_color uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: userDataFloat uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: userDataVector uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: userDataColor uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: userDataString uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaShadingEngine uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaSamplerInfo3D uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: aovWriteVector uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: aovWritePoint uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: aovWritePoint2 uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaNormalDisplacement uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaVectorDisplacement uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: userDataBool uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: shadowCatcher uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaHair uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: meshLightMaterial uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: userDataPnt2 uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: userDataInt uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: mayaBump2D uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: mayaFluid uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: mayaMarble uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: mayaMountain uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: mayaWater uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: mayaCrater uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: mayaLeather uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: mayaGranite uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: mayaRock uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaSingleShadingSwitch uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaDoubleShadingSwitch uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaTripleShadingSwitch uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaQuadShadingSwitch uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaFluidData uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: MayaFluidTexture2D uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: skin uses Arnold 4.2.16.0
00:00:00   352MB         |  mtoa_shaders.dll: volume_collector uses Arnold 4.2.16.0
00:00:00   353MB         |  mtoa_shaders.dll: MayaSurfaceLuminance uses Arnold 4.2.16.0
00:00:00   353MB         |  mtoa_shaders.dll: cameraUvMapper uses Arnold 4.2.16.0
00:00:00   353MB         |  mtoa_shaders.dll: volume_sample_float uses Arnold 4.2.16.0
00:00:00   353MB         |  mtoa_shaders.dll: volume_sample_rgb uses Arnold 4.2.16.0
00:00:00   353MB         |  mtoa_shaders.dll: curvature uses Arnold 4.2.16.0
00:00:00   353MB         |  mtoa_shaders.dll: driver_mplay uses Arnold 4.2.16.0
00:00:00   353MB         | loaded 97 plugins from 1 lib(s) in 0:00.00
00:00:00   353MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/bifrost_shaders.dll ...
00:00:00   353MB         |  bifrost_shaders.dll: bifrostFoamMaterial uses Arnold 4.2.16.0
00:00:00   353MB         |  bifrost_shaders.dll: bifrostAeroMaterial uses Arnold 4.2.16.0
00:00:00   353MB         | loaded 2 plugins from 1 lib(s) in 0:00.00
00:00:00   353MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/hairPhysicalShader_shaders.dll ...
00:00:00   353MB         |  hairPhysicalShader_shaders.dll: HairPhysicalShaderDiffuseColorAdapter uses Arnold 4.2.16.0
00:00:00   353MB         |  hairPhysicalShader_shaders.dll: HairPhysicalShaderSpecularWeightAdapter uses Arnold 4.2.16.0
00:00:00   353MB         |  hairPhysicalShader_shaders.dll: HairPhysicalShaderSpecularGlossAdapter uses Arnold 4.2.16.0
00:00:00   353MB         |  hairPhysicalShader_shaders.dll: HairPhysicalShaderTransmissionWeightAdapter uses Arnold 4.2.16.0
00:00:00   353MB         |  hairPhysicalShader_shaders.dll: HairPhysicalShaderTransmissionSpreadAdapter uses Arnold 4.2.16.0
00:00:00   353MB         | loaded 5 plugins from 1 lib(s) in 0:00.00
00:00:00   353MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/lookdevkit_shaders.dll ...
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkFloatConstant uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkFloatComposite uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkFloatCondition uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkFloatCorrect uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkFloatLogic uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkFloatMask uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkFloatMath uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkColorComposite uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkColorCondition uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkColorConstant uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkColorCorrect uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkColorLogic uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkColorMask uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkColorMath uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkChannels uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkPremultiply uses Arnold 4.2.16.0
00:00:00   353MB         |  lookdevkit_shaders.dll: ldkSimplexNoise uses Arnold 4.2.16.0
00:00:00   353MB         | loaded 17 plugins from 1 lib(s) in 0:00.00
00:00:00   353MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/renderSetup_shaders.dll ...
00:00:00   353MB         |  renderSetup_shaders.dll: applyAbsFloatOverride uses Arnold 4.2.16.0
00:00:00   353MB         |  renderSetup_shaders.dll: applyAbs2FloatsOverride uses Arnold 4.2.16.0
00:00:00   353MB         |  renderSetup_shaders.dll: applyAbs3FloatsOverride uses Arnold 4.2.16.0
00:00:00   353MB         | loaded 3 plugins from 1 lib(s) in 0:00.00
00:00:00   353MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/shave_shaders.dll ...
00:00:00   353MB         |  shave_shaders.dll: ShaveHair uses Arnold 4.2.15.1
00:00:00   353MB         | loaded 1 plugins from 1 lib(s) in 0:00.00
00:00:00   353MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/xgenSpline_shaders.dll ...
00:00:00   353MB         |  xgenSpline_shaders.dll: XGenHairMapping uses Arnold 4.2.16.0
00:00:00   353MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alBlackbody.dll ...
00:00:00   353MB         |  alBlackbody.dll: alBlackbody uses Arnold 4.2.12.2
00:00:00   353MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alCache.dll ...
00:00:00   353MB         |  alCache.dll: alCache uses Arnold 4.2.12.2
00:00:00   353MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alCel.dll ...
00:00:00   353MB         |  alCel.dll: alCel uses Arnold 4.2.12.2
00:00:00   353MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alCellNoise.dll ...
00:00:00   354MB         |  alCellNoise.dll: alCellNoise uses Arnold 4.2.12.2
00:00:00   354MB         | loaded 1 plugins from 1 lib(s) in 0:00.00
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alColorSpace.dll ...
00:00:00   354MB         |  alColorSpace.dll: alColorSpace uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alCombineColor.dll ...
00:00:00   354MB         |  alCombineColor.dll: alCombineColor uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alCombineFloat.dll ...
00:00:00   354MB         |  alCombineFloat.dll: alCombineFloat uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alCurvature.dll ...
00:00:00   354MB         |  alCurvature.dll: alCurvature uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alFlake.dll ...
00:00:00   354MB         |  alFlake.dll: alFlake uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alFlowNoise.dll ...
00:00:00   354MB         |  alFlowNoise.dll: alFlowNoise uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alFractal.dll ...
00:00:00   354MB         |  alFractal.dll: alFractal uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alGaborNoise.dll ...
00:00:00   354MB         |  alGaborNoise.dll: alGaborNoise uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alHair.dll ...
00:00:00   354MB         |  alHair.dll: alHair uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alInputScalar.dll ...
00:00:00   354MB         |  alInputScalar.dll: alInputScalar uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alInputVector.dll ...
00:00:00   354MB         |  alInputVector.dll: alInputVector uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alJitterColor.dll ...
00:00:00   354MB         |  alJitterColor.dll: alJitterColor uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alLayer.dll ...
00:00:00   354MB         |  alLayer.dll: alLayer uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alLayerColor.dll ...
00:00:00   354MB         |  alLayerColor.dll: alLayerColor uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alLayerFloat.dll ...
00:00:00   354MB         |  alLayerFloat.dll: alLayerFloat uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alPattern.dll ...
00:00:00   354MB         |  alPattern.dll: alPattern uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alRemapColor.dll ...
00:00:00   354MB         |  alRemapColor.dll: alRemapColor uses Arnold 4.2.12.2
00:00:00   354MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alRemapFloat.dll ...
00:00:00   354MB         |  alRemapFloat.dll: alRemapFloat uses Arnold 4.2.12.2
00:00:00   355MB         | loaded 1 plugins from 1 lib(s) in 0:00.00
00:00:00   355MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alSurface.dll ...
00:00:00   355MB         |  alSurface.dll: alSurface uses Arnold 4.2.12.2
00:00:00   355MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alSwitchColor.dll ...
00:00:00   355MB         |  alSwitchColor.dll: alSwitchColor uses Arnold 4.2.12.2
00:00:00   355MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alSwitchFloat.dll ...
00:00:00   355MB         |  alSwitchFloat.dll: alSwitchFloat uses Arnold 4.2.12.2
00:00:00   355MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/alTriplanar.dll ...
00:00:00   355MB         |  alTriplanar.dll: alTriplanar uses Arnold 4.2.12.2
00:00:00   355MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/cryptomatte_aov.dll ...
00:00:00   355MB         |  cryptomatte_aov.dll: cryptomatte_aov uses Arnold 4.2.12.2
00:00:00   355MB         | loading plugin: C:/solidangle/mtoadeploy/2017/shaders/cryptomatte_filter.dll ...
00:00:00   355MB         |  cryptomatte_filter.dll: cryptomatte_filter uses Arnold 4.2.12.2
00:00:00   355MB         | loading plugins from C:\solidangle\mtoadeploy\2017\shaders ...
00:00:00   355MB         |  alBlackbody.dll: alBlackbody uses Arnold 4.2.12.2
00:00:00   355MB WARNING |  node "alBlackbody" is already installed
00:00:00   355MB         |  alCache.dll: alCache uses Arnold 4.2.12.2
00:00:00   355MB WARNING |  node "alCache" is already installed
00:00:00   355MB         |  alCel.dll: alCel uses Arnold 4.2.12.2
00:00:00   355MB WARNING |  node "alCel" is already installed
00:00:00   355MB         |  alCellNoise.dll: alCellNoise uses Arnold 4.2.12.2
00:00:00   355MB WARNING |  node "alCellNoise" is already installed
00:00:00   355MB         |  alColorSpace.dll: alColorSpace uses Arnold 4.2.12.2
00:00:00   355MB WARNING |  node "alColorSpace" is already installed
00:00:00   355MB         |  alCombineColor.dll: alCombineColor uses Arnold 4.2.12.2
00:00:00   355MB         |  alCombineFloat.dll: alCombineFloat uses Arnold 4.2.12.2
00:00:00   355MB         |  alCurvature.dll: alCurvature uses Arnold 4.2.12.2
00:00:00   355MB         |  alFlake.dll: alFlake uses Arnold 4.2.12.2
00:00:00   355MB         |  alFlowNoise.dll: alFlowNoise uses Arnold 4.2.12.2
00:00:00   355MB         |  alFractal.dll: alFractal uses Arnold 4.2.12.2
00:00:00   355MB         |  alGaborNoise.dll: alGaborNoise uses Arnold 4.2.12.2
00:00:00   355MB         |  alHair.dll: alHair uses Arnold 4.2.12.2
00:00:00   355MB         |  alInputScalar.dll: alInputScalar uses Arnold 4.2.12.2
00:00:00   355MB         |  alInputVector.dll: alInputVector uses Arnold 4.2.12.2
00:00:00   355MB         |  alJitterColor.dll: alJitterColor uses Arnold 4.2.12.2
00:00:00   355MB         |  alLayer.dll: alLayer uses Arnold 4.2.12.2
00:00:00   355MB         |  alLayerColor.dll: alLayerColor uses Arnold 4.2.12.2
00:00:00   355MB         |  alLayerFloat.dll: alLayerFloat uses Arnold 4.2.12.2
00:00:00   355MB         |  alPattern.dll: alPattern uses Arnold 4.2.12.2
00:00:00   355MB         |  alRemapColor.dll: alRemapColor uses Arnold 4.2.12.2
00:00:00   355MB         |  alRemapFloat.dll: alRemapFloat uses Arnold 4.2.12.2
00:00:00   355MB         |  bifrost_shaders.dll: bifrostFoamMaterial uses Arnold 4.2.16.0
00:00:00   355MB         |  bifrost_shaders.dll: bifrostAeroMaterial uses Arnold 4.2.16.0
00:00:00   355MB         |  hairPhysicalShader_shaders.dll: HairPhysicalShaderDiffuseColorAdapter uses Arnold 4.2.16.0
00:00:00   355MB         |  hairPhysicalShader_shaders.dll: HairPhysicalShaderSpecularWeightAdapter uses Arnold 4.2.16.0
00:00:00   355MB         |  hairPhysicalShader_shaders.dll: HairPhysicalShaderSpecularGlossAdapter uses Arnold 4.2.16.0
00:00:00   355MB         |  hairPhysicalShader_shaders.dll: HairPhysicalShaderTransmissionWeightAdapter uses Arnold 4.2.16.0
00:00:00   355MB         |  hairPhysicalShader_shaders.dll: HairPhysicalShaderTransmissionSpreadAdapter uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkFloatConstant uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkFloatComposite uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkFloatCondition uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkFloatCorrect uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkFloatLogic uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkFloatMask uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkFloatMath uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkColorComposite uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkColorCondition uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkColorConstant uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkColorCorrect uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkColorLogic uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkColorMask uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkColorMath uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkChannels uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkPremultiply uses Arnold 4.2.16.0
00:00:00   355MB         |  lookdevkit_shaders.dll: ldkSimplexNoise uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaMultiplyDivide uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaClamp uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaGammaCorrect uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaCondition uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaReverse uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaBlendColors uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaSamplerInfo1D uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaSamplerInfo2D uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaPlusMinusAverage1D uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaPlusMinusAverage2D uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaPlusMinusAverage3D uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaRemapValueToValue uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaRemapValueToColor uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaRemapColor uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaFile uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaPlace2DTexture uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaRamp uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaProjection uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MeshInfo uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaChecker uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaBulge uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaCloth uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaGrid uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaFractal uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaNoise uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaPlace3DTexture uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaRgbToHsv uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaHsvToRgb uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaLuminance uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaCloud uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaCloudAlpha uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaSnow uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaContrast uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaLayeredTexture uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaLayeredShader uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaSolidFractal uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaVolumeNoise uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaBrownian uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaStucco uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaRemapHsv uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaSetRange uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaImagePlane uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaSurfaceShader uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: colorToFloat uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: vectorToFloat uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: pointToFloat uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: point2ToFloat uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: writeColor uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: aovWriteColor uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: writeFloat uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: aovWriteFloat uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaEnvSphere uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: anim_matrix uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: anim_float uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: anim_point uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: anim_vector uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: anim_color uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: userDataFloat uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: userDataVector uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: userDataColor uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: userDataString uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaShadingEngine uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaSamplerInfo3D uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: aovWriteVector uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: aovWritePoint uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: aovWritePoint2 uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaNormalDisplacement uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaVectorDisplacement uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: userDataBool uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: shadowCatcher uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaHair uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: meshLightMaterial uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: userDataPnt2 uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: userDataInt uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: mayaBump2D uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: mayaFluid uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: mayaMarble uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: mayaMountain uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: mayaWater uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: mayaCrater uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: mayaLeather uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: mayaGranite uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: mayaRock uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaSingleShadingSwitch uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaDoubleShadingSwitch uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaTripleShadingSwitch uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaQuadShadingSwitch uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaFluidData uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaFluidTexture2D uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: skin uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: volume_collector uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: MayaSurfaceLuminance uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: cameraUvMapper uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: volume_sample_float uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: volume_sample_rgb uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: curvature uses Arnold 4.2.16.0
00:00:00   355MB         |  mtoa_shaders.dll: driver_mplay uses Arnold 4.2.16.0
00:00:00   355MB         |  renderSetup_shaders.dll: applyAbsFloatOverride uses Arnold 4.2.16.0
00:00:00   355MB         |  renderSetup_shaders.dll: applyAbs2FloatsOverride uses Arnold 4.2.16.0
00:00:00   355MB         |  renderSetup_shaders.dll: applyAbs3FloatsOverride uses Arnold 4.2.16.0
00:00:00   355MB         |  shave_shaders.dll: ShaveHair uses Arnold 4.2.15.1
00:00:00   355MB         |  xgenSpline_shaders.dll: XGenHairMapping uses Arnold 4.2.16.0
00:00:00   355MB         | loaded 154 plugins from 35 lib(s) in 0:00.02
00:00:00   355MB WARNING |  [mtoa.ext]  aiAOVDriver Found no translator named "maya"
00:00:00   355MB WARNING | cannot declare constant STRING render_layer on options - name already in use
00:00:00   355MB WARNING | cannot declare constant FLOAT fps on options - name already in use
00:00:00   356MB WARNING | cannot declare constant STRING render_layer on options - name already in use
00:00:00   356MB WARNING | cannot declare constant FLOAT fps on options - name already in use
00:00:00   356MB         |
00:00:00   356MB         | [rlm] checkout of "arnold 20161122" in progress ...
00:00:00   357MB         | [rlm] checkout of "arnold 20161122" from server LIC in 0:00.02
00:00:00   357MB         | [rlm] expiration date: 20-oct-2017 (298 days left)
00:00:00   357MB         |
00:00:00   372MB         |
00:00:00   372MB         | there are 2 lights and 4 objects:
00:00:00   372MB         |       2 persp_camera
00:00:00   372MB         |       1 quad_light
00:00:00   372MB         |       1 skydome_light
00:00:00   372MB         |       2 utility
00:00:00   372MB         |       1 light_decay
00:00:00   372MB         |       1 standard
00:00:00   372MB         |       1 physical_sky
00:00:00   372MB         |       6 driver_exr
00:00:00   372MB         |       1 box_filter
00:00:00   372MB         |       1 gaussian_filter
00:00:00   372MB         |       3 polymesh
00:00:00   372MB         |       1 list_aggregate
00:00:00   372MB         |       3 MayaShadingEngine
00:00:00   372MB         |       1 alSurface
00:00:00   372MB         |       1 batch_progress_driver
00:00:00   372MB         |
00:00:00   372MB         | rendering image at 640 x 480, 4 AA samples
00:00:00   372MB         |   AA sample clamp   <disabled>
00:00:00   372MB         |   diffuse           samples  4 / depth  1
00:00:00   372MB         |   glossy            samples  2 / depth  1
00:00:00   372MB         |   reflection        samples  1 / depth  2
00:00:00   372MB         |   refraction        samples  2 / depth  2
00:00:00   372MB         |   volume indirect   <disabled by depth>
00:00:00   372MB         |   total                          depth 10
00:00:00   372MB         |   bssrdf            samples  1
00:00:00   372MB         |   single scatter    samples  5
00:00:00   372MB         |   transparency      depth 10 / threshold 0.99 / fast opacity on
00:00:00   372MB         |  initializing 27 nodes ...
00:00:00   372MB WARNING |   cameraShape1: ignoring scaling component in camera matrix
00:00:00   372MB         |   creating root object list ...
00:00:00   372MB         |  node initialization done in 0:00.04 (single-threaded)
00:00:00   372MB         |  updating 28 nodes ...
00:00:00   372MB         |   |aiAreaLight1|aiAreaLight1: quad_light using 2 samples, disabled for volumes
00:00:00   372MB         |   aiSkyDomeLightShape1: skydome_light using 3 samples, disabled for volumes
00:00:00   373MB WARNING |   options: parameter "sss_bssrdf_samples" is deprecated, use "GI_sss_samples"
00:00:00   373MB         |   scene bounds: (-14.5023651 -0.307041943 -14.5023651) -> (14.5023651 11.5403709 14.5023651)
00:00:00   373MB         |  node update done in 0:00.01 (single-threaded)
00:00:00   373MB         |  [aov] registered driver: "defaultArnoldDriver@driver_exr.RGBA.depth" (driver_exr)
00:00:00   373MB         |  [aov]  * "depth" of type RGB filtered by "defaultArnoldFilter@gaussian_filter" (gaussian_filter)
00:00:00   373MB         |  [aov] registered driver: "defaultArnoldDriver@driver_exr.RGBA.diffuse_color" (driver_exr)
00:00:00   373MB         |  [aov]  * "diffuse_color" of type RGB filtered by "defaultArnoldFilter@gaussian_filter" (gaussian_filter)
00:00:00   373MB         |  [aov] registered driver: "defaultArnoldDriver@driver_exr.RGBA" (driver_exr)
00:00:00   373MB         |  [aov]  * "RGBA" of type RGBA filtered by "defaultArnoldFilter@gaussian_filter" (gaussian_filter)
00:00:00   373MB         |  [aov] registered driver: "progress_driver" (batch_progress_driver)
00:00:00   373MB         |  [aov]  * "Z" of type FLOAT filtered by "progress_driver_filter" (box_filter)
00:00:00   373MB         |  [aov] registered driver: "defaultArnoldDriver@driver_exr.RGBA.direct_specular" (driver_exr)
00:00:00   373MB         |  [aov]  * "direct_specular" of type RGB filtered by "defaultArnoldFilter@gaussian_filter" (gaussian_filter)
00:00:00   373MB         |  [aov] registered driver: "defaultArnoldDriver@driver_exr.RGBA.indirect_diffuse" (driver_exr)
00:00:00   373MB         |  [aov]  * "indirect_diffuse" of type RGB filtered by "defaultArnoldFilter@gaussian_filter" (gaussian_filter)
00:00:00   373MB         |  [aov] registered driver: "defaultArnoldDriver@driver_exr.RGBA.direct_diffuse" (driver_exr)
00:00:00   373MB         |  [aov]  * "direct_diffuse" of type RGB filtered by "defaultArnoldFilter@gaussian_filter" (gaussian_filter)
00:00:00   373MB         |  [aov] done preparing 7 AOVs for 7 outputs to 7 drivers (0 deep AOVs)
00:00:01   411MB         |  starting 48 bucket workers of size 64x64 ...
00:00:01   728MB         |     0% done - 36 rays/pixel
00:00:01   728MB         |     5% done - 85 rays/pixel
00:00:01   734MB         |    10% done - 142 rays/pixel
00:00:02   736MB         |    15% done - 335 rays/pixel
00:00:03   756MB         |    20% done - 685 rays/pixel
00:00:05   791MB         |    25% done - 733 rays/pixel
00:00:05   797MB         |    30% done - 297 rays/pixel
00:00:05   800MB         |    35% done - 226 rays/pixel
00:00:06   848MB         |    40% done - 634 rays/pixel
00:00:07   885MB         |    45% done - 846 rays/pixel
00:00:07   895MB ERROR   |   signal caught: error C0000005 -- access violation
* Arnold 4.2.16.0 windows icc-14.0.2 oiio-1.7.7 rlm-12.0.2 2016/11/22 13:25:15
00:00:07   895MB         |    50% done - 39 rays/pixel
00:00:07   895MB         |    55% done - 0 rays/pixel
00:00:07   895MB         |    60% done - 0 rays/pixel
00:00:07   895MB         |    65% done - 0 rays/pixel
00:00:07   895MB         |    70% done - 0 rays/pixel
00:00:07   896MB         |    75% done - 0 rays/pixel
00:00:07   896MB         |    80% done - 0 rays/pixel
00:00:07   896MB         |    85% done - 0 rays/pixel
00:00:07   896MB         |    90% done - 0 rays/pixel
00:00:07   896MB         |    95% done - 0 rays/pixel
* CRASHED in MMutexLock::tryLock at 00:00:00
* signal caught: error C0000005 -- access violation
* backtrace:
*  0 0x00000001808c9c4e [ai        ] AiCreateAtStringData_private
*  1 0x00000001808c8f57 [ai        ] AiCreateAtStringData_private
*  2 0x00007ff984ce1d52 [KERNELBASE] UnhandledExceptionFilter
*  3 0x00007ff98773f133 [ntdll     ] memset
*  4 0x00007ff987721d86 [ntdll     ] _C_specific_handler
*  5 0x00007ff9877333fd [ntdll     ] _chkstk
*  6 0x00007ff9876f4847 [ntdll     ] RtlRaiseException
*  7 0x00007ff98773258a [ntdll     ] KiUserExceptionDispatcher
>> 8 0x00007ff94f6c1b13 [OpenMaya  ] MMutexLock::tryLock
* loaded modules:
*    0x0000000180000000  ai
*    0x00007ff984c00000  KERNELBASE
*    0x00007ff9876a0000  ntdll
*    0x00007ff94f510000  OpenMaya
Stack trace:
  ntdll.dll!RtlRaiseException
  ntdll.dll!KiUserExceptionDispatcher
  OpenMaya.dll!MMutexLock::tryLock
  mtoa.mll!CLightLinkerTranslator::CreateArnoldNodes
  ai.dll!AiMsgDebug
  ai.dll!AiMsgDebug
  ai.dll!AiShaderEvalParamFuncRGB
  MSVCR90.dll!_endthreadex
  KERNEL32.DLL!BaseThreadInitThunk
  ntdll.dll!RtlUserThreadStart
Result: //prod/class/rhagen/test/scenes/test_2017_RS_Arnold__11404.ma
Fatal Error. Attempting to save in C:/Users/rhagen/AppData/Local/Temp/rhagen.20161227.2008.ma
Message 5 of 8
Same problem here with vray:
Warning: 	string $currentRenderer = currentRenderer();
Warning: "/mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64//scripts/others/createMayaSoftwareCommonGlobalsTab.mel" line 3148.45 : Redeclaration of variable "$currentRenderer" shadows previous declaration at line 3143. Previous value will be overwritten by explicit initializer.
I'm using the the old render style system
Message 6 of 8
In my case it has something to do with Bifrost, deleting all bifrost nodes solves the problem
Starting "/mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64/bin/maya"
[2017/Jan/19|11:22:27] V-Ray: V-Ray for Maya version 3.40.06, revision 27073 from Nov 22 2016, 20:37:29
[2017/Jan/19|11:22:27] V-Ray: V-Ray core version is 3.25.01
[2017/Jan/19|11:22:27] V-Ray: Loading plugins from "/mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64/vray/vrayplugins/libvray_*.so"
[2017/Jan/19|11:22:27] V-Ray: 75 plugin(s) loaded successfully
[2017/Jan/19|11:22:28] V-Ray: Finished loading plugins.
Warning: "/mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64//scripts/others/createMayaSoftwareCommonGlobalsTab.mel" line 3153.45 : Redeclaration of variable "$currentRenderer" shadows previous declaration at line 3143. Previous value will be overwritten by explicit initializer.
Warning: "/mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64//scripts/others/createMayaSoftwareCommonGlobalsTab.mel" line 3158.45 : Redeclaration of variable "$currentRenderer" shadows previous declaration at line 3143. Previous value will be overwritten by explicit initializer.
Warning: "/mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64//scripts/others/createMayaSoftwareCommonGlobalsTab.mel" line 3163.45 : Redeclaration of variable "$currentRenderer" shadows previous declaration at line 3143. Previous value will be overwritten by explicit initializer.
Warning: "/mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64//scripts/others/createMayaSoftwareCommonGlobalsTab.mel" line 3168.45 : Redeclaration of variable "$currentRenderer" shadows previous declaration at line 3143. Previous value will be overwritten by explicit initializer.
Warning: "/mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64//scripts/others/createMayaSoftwareCommonGlobalsTab.mel" line 3173.45 : Redeclaration of variable "$currentRenderer" shadows previous declaration at line 3143. Previous value will be overwritten by explicit initializer.
Warning: "/mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64//scripts/others/createMayaSoftwareCommonGlobalsTab.mel" line 3178.45 : Redeclaration of variable "$currentRenderer" shadows previous declaration at line 3143. Previous value will be overwritten by explicit initializer.
Warning: "/mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64//scripts/others/createMayaSoftwareCommonGlobalsTab.mel" line 3183.45 : Redeclaration of variable "$currentRenderer" shadows previous declaration at line 3143. Previous value will be overwritten by explicit initializer.
[Thu Jan 19 11:22:27 2017] Yeti 2.1.3: Yeti v2.1.3, built on Nov 19 2016 at 11:39:18
[Thu Jan 19 11:22:27 2017] Yeti 2.1.3: (c) 2010-Present Peregrine Labs a division of Peregrine Visual Storytelling Ltd. All rights reserved.
[2017/Jan/19|11:22:28] V-Ray: Registered dynamic node vrayMultiProjection (id: 1115335/0x001104C7)
[2017/Jan/19|11:22:28] V-Ray: Registered dynamic node VRayCurvature (id: 1115347/0x001104D3)
[2017/Jan/19|11:22:28] V-Ray: Registered dynamic node VRayTriplanar (id: 1115362/0x001104E2)
[2017/Jan/19|11:22:28] V-Ray: Registered dynamic node VRaySkinMtl (id: 1115348/0x001104D4)
[2017/Jan/19|11:22:28] V-Ray: Registered dynamic node VRayPointParticleMtl (id: 1115353/0x001104D9)
[2017/Jan/19|11:22:28] V-Ray: Registered dynamic node VRayStochasticFlakesMtl (id: 1115359/0x001104DF)
AbcImport v1.0 using Alembic 1.5.8 (built Dec 24 2015 17:39:02)
	Warning: The port 'readLiquidCache::liquid' does not have a type.
	Warning: The port 'readLiquidCache::solids' does not have a type.
	Warning: The node definition 'Bifrost::Nodes::Object::readObjectFromCacheUsingName' could not be resolved for node 'readLiquidCache::readObjectFromCacheUsingName1'.
	Warning: The node definition 'Bifrost::Nodes::Object::readObjectFromCacheUsingName' could not be resolved for node 'readLiquidCache::readObjectFromCacheUsingName2'.
	Warning: The node definition 'Bifrost::Nodes::Misc::createFilepath' could not be resolved for node 'readLiquidCache::createPath1'.
	Warning: The node definition 'Bifrost::Nodes::Misc::createFilepath' could not be resolved for node 'readLiquidCache::createPath2'.
	Warning: The node definition 'Bifrost::Nodes::Misc::concatString' could not be resolved for node 'readLiquidCache::concatString1'.
	Warning: The node definition 'Bifrost::Nodes::Misc::concatString' could not be resolved for node 'readLiquidCache::concatString2'.
	Warning: One or more parameters are invalid in the connection involving 'readObjectFromCacheUsingName1.object' and '.liquid' (source port not found on node).
	Warning: One or more parameters are invalid in the connection involving 'readObjectFromCacheUsingName2.object' and '.solids' (source port not found on node).
	Warning: One or more parameters are invalid in the connection involving '.path' and 'concatString1.str' (target port not found on node).
	Warning: One or more parameters are invalid in the connection involving '.path' and 'concatString2.str' (target port not found on node).
	Warning: One or more parameters are invalid in the connection involving 'concatString1.value' and 'createPath1.str' (source port not found on node).
	Warning: One or more parameters are invalid in the connection involving 'concatString2.value' and 'createPath2.str' (source port not found on node).
	Warning: One or more parameters are invalid in the connection involving 'createPath1.value' and 'readObjectFromCacheUsingName1.cachePath' (source port not found on node).
	Warning: One or more parameters are invalid in the connection involving 'createPath2.value' and 'readObjectFromCacheUsingName2.cachePath' (source port not found on node).
	Warning: The port 'str2' could not be found in compound 'readLiquidCache'.
	Warning: The port 'reuseTarget' could not be found in compound 'readLiquidCache'.
	Warning: The node definition 'Bifrost::Nodes::_private::fetchObject' could not be resolved for node 'createBaseObject::fetchObject'.
	Warning: One or more parameters are invalid in the connection involving 'fetchObject.object' and 'clearPropertyValues.object' (source port not found on node).
	Warning: One or more parameters are invalid in the connection involving '.name' and 'fetchObject.name' (target port not found on node).
Error: line 1: line 1: Cannot find procedure "nodeEdRefreshVnnNodeTreeListers".
[BossBlender] Created a new BOSS Blender
Warning: line 1: Errors have occurred while reading this scene that may result in data loss.
File read in  45.8 seconds.
Warning: Bifrost: to use the new 2017 update 2 Bifrost features, graph |bifrostLiquid1|bifrostLiquidContainer1 needs to be updated to the latest version, call mel script: replaceBifrostFXGraphsWithFactoryGraphs |bifrostLiquid1|bifrostLiquidContainer1 ;
Stack trace:
  /mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64//plug-ins/bifrost/lib/libbifrostfluid.so(+0x466005) [0x7f8fd2943005]
  tbb::interface9::internal::start_for<tbb::blocked_range<int>, Bifrost::ParticleMesh::Worker<Bifrost::VoxelShape, Bifrost::ParticleShape>::createLevelSet(std::shared_ptr<Bifrost::VoxelShape> const&, std::shared_ptr<Bifrost::VoxelLayout> const&, std::shared_ptr<Bifrost::VoxelChannel<float> > const&, std::shared_ptr<Bifrost::VoxelChannel<unsigned long> >, std::shared_ptr<Bifrost::VoxelChannel<float> >, std::shared_ptr<Bifrost::VoxelChannel<float> >, std::shared_ptr<Bifrost::VoxelChannel<float> >, std::shared_ptr<Bifrost::ParticleShape> const&, std::shared_ptr<Bifrost::VoxelLayout> const&, std::shared_ptr<Bifrost::ParticleChannel<amino::Math::vec<3u, float> > > const&, std::shared_ptr<Bifrost::ParticleChannel<float> > const&, std::shared_ptr<Bifrost::VoxelShape> const&, std::shared_ptr<Bifrost::VoxelChannel<float> > const&, float, float, float, float, float, float, bool, bool, bool)::{lambda(tbb::blocked_range<int> const&)#3}::operator()(tbb::blocked_range<int> const&) const::{lambda(tbb::blocked_range<int> const&)#1}, tbb::auto_partitioner const>::execute()
  /mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64//lib/libtbb.so.2(+0x26ff2) [0x7f908d8d7ff2]
  /mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64//lib/libtbb.so.2(+0x223d9) [0x7f908d8d33d9]
  /mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64//lib/libtbb.so.2(+0x2084f) [0x7f908d8d184f]
  /mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64//lib/libtbb.so.2(+0x1c486) [0x7f908d8cd486]
  /mnt/maitre-d/linux/maya/autodesk2017/maya2017-x64//lib/libtbb.so.2(+0x1c416) [0x7f908d8cd416]
  /lib/x86_64-linux-gnu/libpthread.so.0(+0x8182) [0x7f908b8b9182]
  clone
Fatal Error. Attempting to save in /usr/tmp/.20170119.1126.ma
Writing crash report in /usr/tmp/.20170119.1126.crash
// Maya exited with status 1
Message 7 of 8
To be more specific it is crashing on bifrost meshing. If I disable bifrost meshing it renders without problems.
Message 8 of 8
smbell1979
Did you ever solve this issue. We are having the same problem with vray on 4 out of 10 render nodes on our farm, it's driving us crazy.
