Maya 2015 Texture Problem
Help?
Anyone have ideas to help with this texture and model window issue?
PROBLEM:  The model does not show any textures that are being applied.  The textures are being applied because a (rough) render shows them.
I have selected the "6" view (shaded display with texture maps is ON).
As a test, I started a new file and created a quick model of an eye ball - both the model and the textures show in the model window!  So this problem is not being seen consistently, it's only for this particular model, this particular file.
I have tried switching the "renderer" - from Viewport 2.0 to the Legacy Default Viewport and the Legacy High Quality Viewport - this did not change the problem.
I'm using a MacBook Pro OSX 10.9.2, Maya 2015, Student Ed.
_sebastian_f
you don´t have textured view active. the icon on top of your viewport is disabled but the "use default material" toggle is active. uncheck this and activate textured view.
Many thanks Sebastian! Forgive the new user here, this software is a beast for the newbie...
_sebastian_f
you´re welcome and don´t worry it will become easier over time!
Many Many Thanks sebastian_freigang ...I had the same problem with texturing...:D
