lookdevX arnold image node file sequence
ocampbellhobson
ocampbellhobson
is there any way to use a file sequence in lookdevX arnold image node? in hypershade all you had to do was check the use file sequence box and add the # token in place of the frame number, I can add that token to the filename but I cannot find a way to add a frame expression.
lauri_barnhart
Hello @ocampbellhobson, thanks for posting in the community!
Are you still experiencing issues?
If you've found a solution, please share it here so other users benefit from the information.
In case you still need help, please provide an update here so we can help you best moving forward.
Best,
Lauri | Community Manager
Stephen.Blair
LookDevX doesn't support frame sequences yet for the Image node.
// Stephen Blair
// Arnold Renderer Support
lauri_barnhart
Hello @ocampbellhobson], thanks for posting in the community!
Did the information provided by @Stephen.Blair help?
If yes, please mark the reply as the accepted solution.
This helps other community user find a solution to similar problems.
Thanks!
