Issue with rendering via MayaBatch - Reference Files
Hi Everyone,
We are using Maya 2018.3 and RedShift for rendering, combined with Thinkbox Deadline for group rendering. All works well except when we send Mayabatch render commands we get an instantly failure with a generic error code and I am not sure why. I made a post but I think it was deleted which I am also not sure why? We are using Windows 10, GTX1080s, 32GBs of Ram on the system.
The command is:
"C:\Program Files\Autodesk\Maya2018\bin\Render.exe" -r redshift -x 1920 -y 1080 -s 48 -e 48 -b 1 -rd "Y:/********/CWL_Elevate/CGI/Maya/images" -im "<Scene>/<Camera>" -proj "Y:/********/CWL_Elevate/CGI/Maya" "Y:\********\CWL_Elevate\CGI\Maya\scenes\Rescue Vignette\Shot1n2_Lighting_v8.mb"
Initialized VP2.0 renderer { Version : 2016.11.40.12. Feature Level 5.
Adapter : NVIDIA GeForce GTX 1080 Ti
Vendor ID: 4318. Device ID : 6918
Driver : C:\Windows\System32\DriverStore\FileRepository\nvdd.inf_amd64_1beb6cbf8800706c\nvldumdx.dll,C:\Windows\System32\DriverStore\Fil:23.21.13.8795.
API : DirectX V.11.
Max texture size : 16384 * 16384.
Max tex coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Active stereo support available : 0
GPU Memory Limit : 11264 MB.
CPU Memory Limit: 62076.1 MB.}
OpenCL evaluator is attempting to initialize OpenCL.
Detected 2 OpenCL Platforms:
0: Intel(R) Corporation. Intel(R) OpenCL. OpenCL 2.1 .
Supported extensions: cl_intel_dx9_media_sharing cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_depth_images cl_khr_dx9_media_sharing cl_khr_fp64 cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_image2d_from_buffer cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_spir
1: NVIDIA Corporation. NVIDIA CUDA. OpenCL 1.2 CUDA 9.1.56.
Supported extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts cl_nv_create_buffer
OpenCL evaluator choosing OpenCL platform NVIDIA Corporation.
Choosing OpenCL Device GeForce GTX 1080 Ti. Device Type: GPU Device is available.
[Redshift] Redshift for Maya 2018
[Redshift] Version 2.6.21, Sep 6 2018
// Maya exited with status 1
And then it exits with a generic error code of 1.
