Is there a way to make modeling color brighter ?
Hello! I noticed when I am modeling, my shapes and everything seems like to be a lot darker color and they are not so bright anymore. What can I do to change that? Its not happening during render view or anything, just during the modeling.
daunish
Not sure how it looks for you. But the standard should look fine for modeling (at least for me). I've uploaded two files.:
One "Standard_Viewport" how it looks for me, is this how it looks for you?
The other called "ColorManagementOff_Viewport" if your view looks like this, then I agree it's too dark, and you probably accidentally turned off color management, just turn it back on.
If the standard viewport is too dark, there are a few things you can do.
On the default lambert, just make it a brighter white.
Or, check out the 3rd image I attached called "GammaControl_Viewport" change the drop-down to something that works better for you.
If it's still too dark, then you got a bigger problem here. Maybe upload a screenshot if that's the case. Let me know
