Invert ramp values
Invert ramp values
PuChiNgBaLLz
Invert ramp values
PuChiNgBaLLz
Hi there, i'm trying to use a ramp map as a unique node to control 2 values of an Arnold aiStandardSurface material, this is what i have and the red draw is what i need, so this allows me to just modify 1 ramp node and affect multiple inputs, which node do i need to use there or how can i get an inverted value from the same ramp?
hamsterHamster
I believe, you can use aiColorCorrect node with Invert switch enabled.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
PuChiNgBaLLz
I've tried and worked but in the Alpha section of the aicolorcorrect, btw, is there any chance to tweek the black and white tones in the same aicolorcorrect or i need to connect it to another aicolorcorrect? The current ramp is white in the center & black outside, the invert already done just swaped the values, now i have to correct this since is too rough, too White.
hamsterHamster
Why wouldn't you connect
ramp1.outColor to aiColorCorrect2.input, then
aiColorCorrect2.outColorR to Esciera.specularRoughness
and invert the color, like I shown in my picture before?
Besides, all the multiply, add, exposure etc. attributes there are to correct the output.
,,,_°(O__O)°_,,,
