Invalid Syntax error - UDIM workflow
piecloud
piecloud
I've seen other posts on this topic, but everyone is having rather different setups.
I am trying to apply textures to my model. When I select my texture file and then select tiling mode to UDIM (Mari) I get this error:
# Error: file: C:/Program Files/Autodesk/Maya2023/scripts/AETemplates/AEfileTemplate.mel line 699: invalid syntax
Textures don't tile correctly, can't use them.
Deleted preferences, reinstalled maya. Tried it in 2022 and 2023. No difference. Just finished another project last week and everything worked fine. Why is this 'industry standard' software such a piece of junk?
Christoph_Schaedl
How are your textures named?
https://linktr.ee/cg_oglu
iris_vega
Hi, I'm not the one who asked but I have the same problem.
My textures are called like this:
Christoph_Schaedl
Have you tried to use the <UDIM> tag in the filename?
iris_vega
I already found the problem!! Was the name of an old folder (there's where I put the textures). I had and ' on it. Thank you anyways :)<3
