Importing 2D Image file as 3D Texture?
I've been trying to UV two separate pieces of NURBS surfaces as a single uniform material, but the textures show up bigger on one piece and smaller on the other.
Hence, I've decided to try to 3D texture both pieces instead.
Is it possible to import a 2D image file and use it as a 3D texture?
Thanks very much.
mspeer
Hi!
You can use a Projection for 2D images, but you can't convert them to "real" 3D textures.
cavescholar
It sounds like you might be interested in displacement maps
Good luck, have fun!
