I want to blend the ground and the object
g020g140523VJV
g020g140523VJV
https://youtu.be/6auecD4Rhx4
このビデオで行われていることをMayaを使ってやりたいのですが、誰か知っていますか?
Replies (11)
g020g140523VJV
P.S. You can blend materials, but vertex normals are not blended, so the appearance remains uncomfortable.
damaggio
Yes , you can achieve a similar result with a Round Corners shader  and mask the texture transition with a Blend shader.
g020g140523VJV
Thank you for the great information. Does the same thing happen with vray?
damaggio
yes, you can do it with Arnold Vray and Renderman.You gonna also need a ramp or texture mask  for the transition
g020g140523VJV
I tried Vray Round Edges, which had a similar feature, but beveled sharp objects such as cubes, but had no effect on natural assets such as Mega Scan.
g020g140523VJV
Sorry could you make a tutorial video if you like?
damaggio
I've made a simple scene here where blend materials are used to transition the two surfaces together, just keep in mind that just like the Blender tutorials it's nothing more than a trick of lighting on the vertex normals, just like a normal map so it won't work in certain occasions nor if looked closely.
I'm sure this can be improved upon but it's a fast way to get that blending on your scenes.
It's important to read the documentation about these nodes whether is Vray or any other renderer so you can fully understand its applications.
One last thing to note in this scene is that the Round Edges  is applied onto the shader, the Blend material not the geo, then the transition with a Ramp  and the round edges at a very high settings 15 in this case.
Round_Edges.jpgusually is supposed to be applied at a very small numbers like 0.5 to 0.1 in scene units.
You can still apply another Round Edges with a small value for the actual geometry.
So now just play with the scene and see if it helps in your project. Good luck.Blend.jpg
damaggio
If you are using some mega scan  assets then you gonna need to use a ramp with a projection node do ignore the UVs from mega scan
damaggio
If you are using some mega scan  assets then you gonna need to use a ramp with a projection node to ignore the UVs from mega scan.
g020g140523VJV
Thank you for teaching me politely. I will refer to it.
damaggio
Another  very handy node is a distance texture to blend one shader to another which doesn't involve UVs, the same also by painting a vertex color map to blend the two materials.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
