How to select faces by Its Material?
Message 1 of 9
Is there a way I can select all the faces which are assigned to a certain material?
Replies (8)
Message 2 of 9
J450NP13
Go into the hypershader and right click on a shader and select select objects by material.
Message 3 of 9
jewboy0117
this is not an answer to selecting faces, only objects with said materials. If you have an object with multiple materials then this can be a problem.
Message 4 of 9
If you follow the steps above, you can selected faces with different materials in the same object.
Message 5 of 9
Climber_FX
The problem is only when you want to select the faces of only one of many objects that have this particular shader between many others. If you have one object with multi materials, it select only the faces with your choice on the object.
Message 6 of 9
Christoph_Schaedl
Use this Python script.
import maya.cmds as mc
# select object or face
b = mc.ls(sl=1)[0].split("[")[0] # remember a token for comparison below
mc.hyperShade(smn=1) # that will select the shader
s = mc.ls(sl=1)[0] # remember the selected shader
sg = mc.listConnections(s+".oc", s=0, d=1)[0] # figure out the shading group
# select the faces of the same object with same shader attached
l = []
for o in mc.sets(sg, q=1):
    if b not in o: continue
    l.append(o)
mc.select(l)
https://linktr.ee/cg_oglu
Message 7 of 9
andymc4997
Hi, I really need this script to work, as I have multiple objects which have multiple shaders assigned. However, I'm receiving this error for a given material:
Error: ValueError: file <maya console> line 6: No object matches name: Metal.oc
"Metal" is the shader I'm trying to switch out with a different one on my selected object. Can this be fixed?
My specs:
Maya '20
Win10 64bit
Thanks so much in advance.
Message 8 of 9
kopacabana
Hi Andy,
If you need to select another shader, specify the index (change 0 by another index) :
s = mc.ls(sl=1)[0]
For the ".oc" problem, replace :
with :
sg = mc.listConnections(s, s=0, d=1)[0]
Message 9 of 9
sux
