Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
how to change texture quality?
4 REPLIES 4
yadavchandrabhan59
415 Views, 4 Replies
is there any node or attribute to change texture quality while rendering per object meanwhile I plugged 4k texture in every object but I dont need in every object is there anyway to reduce quality of in those objects.
4 REPLIES 4
Reducing the original texture is the most effective way.
https://linktr.ee/cg_oglu
but is there any option or node something to do that?
Could you explain it further why you want a node todo that?
Cause if you use a node you read in the original data and process it. So you wont get any speed or memory gains. And if an object is far away the renderer does load a mipmap anyway.
If you have a pyramid mipmap file texture, the image will be rendered at full resolution and at smaller resolutions as the object moves away from camera or objects in the Bg as Chris explained.
Today's renderers can do this on the fly to save on memory, as an example Arnold uses .tx but there's also exr, tiff and dds . Also remember that having large image textures will slow down Maya opening, saving and viewport performance, after that comes the render engine that needs to load everything into memory.
There are many ways to optimize one's rendering performance depending on the job at hand.
You can also covert manually any texture to a mipmap format as long as they are power of 2 to help the rendering but viewport performance will remain the same because the texture is always at full resolution unless you control it in the viewport 2.0 settings "Clamp texture resolution".
There's no need to use a copy of a 4K texture at a lower resolution for another object since you already loaded the 4K texture into Maya anyway, so just keep using  in as many objects as you want within the scene. You only need smaller resolution for distant objects.( but the renderer can also take care of that as explained prior). You can read more about this in the docs or online.
Technology Administrators
