Help with low-poly shaders
I'm looking to create a shader like this one, only not in Unity, but in Maya. I have little experience with shaders in Maya, and am finding it very difficult to find many resources on how to approach something like this (below) - everything I've found is for Cinema4d or Unity.
If anyone could walk me through how to do it, or point me in the direction of a tutorial that already does, I'd be deeply appreciative!
Thank you!
http://polyknightgames.com/world-building-shaders-and-aesthetics/
Replies (8)
mspeer
Hi!
If i search for Toon Shader in Maya Documentation / Online Help the first item found is Ramp Shader, exactly what you need!?
http://help.autodesk.com/view/MAYAUL/2017/ENU/?guid=GUID-022F69B8-B1A3-46A3-9917-0D9CBDBB6733
Thank you! Yes - I think that's a start, but I need a bit more direction, if you can help!
This guy - Eran Hilleli is a great representation of what I'm hoping to do.
I have low poly models, but I don't want to have shadows directly follow the rough geometry. Look at how the light passes smoothly over the face without making each large face of the mesh super obvious.
More examples:
The gradients:
The soft shadows and the haze:
And one more for good luck:
Just wondering if you might be able to hone in more closely on how to achieve this kind of shader aesthetic.
And here's an example of what I don't want:
Notice how the light and shadows show exactly where every face of the mesh is. Not subtle. Not a bad aesthetic, but not what I'm looking for.
mspeer
Hi!
Mesh Display -> Soften Edge
Hmm, I'm not sure that's it. If you look at the examples, there are some pretty sharp edges in there on occasion. It seems less like a mesh thing and more like a shader thing, to my eye at least.
mspeer
Hi!
See my first reply about shader.
joostkonemann
Indeed, use a ramp shader in which you use hard transitions from one colour to the next.
If you want to use Arnold, which does not support the ramp shader (as far as I know); you can use for instance a aiStandard, from the aiStandard you pipe one of the color out components through a remapValue node into a the V coord of a ramp texture node (delete the placement node), from which you pipe the output in an aiUtility node set to 'flat' shade mode. In the ramp you can set your colours.
See screenshot for the shader node graph and the result.
MacBook Pro 13,3 - 2.7GHz - 16GB - Radeon Pro 460 - macOS Catalina 10.15
I Ran into the same problem.
the answer is easier then you think
Heran Hilleli Examples shows that he uses Spot light and not one with soft edges - like area or point
and that keep the sharp light edge
Example - on the right I put Spot light/On the left side there is point light
