.exr output does not match Render View.
granmail
granmail
I don't have a lot of experience with .exr file output format and was going to start using it with Z-Depth for some simple camera blur effects, but when I render using the .exr format, all of my images look like they have a white haze over them. The renders look fine in the Render View as they are rendering, but when I open up the file after it is completed, the images don't match. I changed the file type to TIF and it renders correctly. Is there something I'm missing about the .exr format that might be causing this? (no z-Depth AOV is being used in these renders yet)
Image 1 - Render View window while rendering.
Image 2 - Render saved as EXR.
Image 3- Render saved as TIF.
Christoph_Schaedl
Exr files are linear files you need to load them with that in mind. Every compositing software should do that out of the box.
What software are you using?
https://linktr.ee/cg_oglu
granmail
The project in which I am working was originally rendered in Maya 2020. Recently I updated all the files to work to work in 2024, but am still using the color management file that I had previously used so my new renders match the old ones. I was able to replicate the look of the older renders in After Effects by loading the same color management file into the project settings there, so I guess I found a solution for working with the .exr renders. Not sure if that's common practice. I was just a little surprised to see such a big difference between what I thought I was rendering and the result the .exr's were giving me. No other file format seemed to have that issue.
Christoph_Schaedl
Its the other way around. All other file formats are creating problems. EXR is 32 bit designed by ILM to solve all kind of issues for compositing.
