Hi everyone! I'm trying to render a sequence using GPU. I only need the beauty, so i'm not trying to separate AOVs because i won't have time for compositing when i need to render. The Sequence render most of the time stops after about 10/12 frames with the message:
Sequence rendering aborted
// Error: [gpu] no GPU matching requirements found for GPU-rendering //
// Warning: Aborted by user: received abort signal //
I deleted the Nvidia drivers of the Rtx 3080, reinstalled the latest version of the studio drivers, reinstalled the latest version of Arnold (as of today), but with the same results. I can't understand what the arnold.log means. To me it seems it slowly fills up the graphic's card memory to its limit, but i can't find ressources about this kind of issue. If anyone was kind enough to give me a clue about what is going wrong... Thanks in advance, best regards.
